$500 - $700 - possibly $1100 for a graphics card
lilwolfgx
Hey, I have $700 and i need a graphics card as at the moment i don't have one at all and i'm running off of a AMD A10 7870K (which i was sorta scammed into at <icrocenter in 2015) so i was planning to get an AMD FX CPU but i'm not sure which to get any suggestions? and i'm also looking for a graphics card something that can play most of my games at 60fps at 1080p but can also handle intensive game creating and game design and video editing which also goes hand and hand with the CPU i was recommended a 1070 and i really am thinking about getting that cause that leaves me enough to get the CPU but if i get a new CPU i'd also need a MOBO  as my MOBO is fm2+ and obsolete and is quite hard to find a decently priced ATX fm2+ socket MOBO and my current MOBO (gigabyte f2a88xm-d3h) which was sold in  a bundle with the CPU doesn't have enough clearance for a MOBO so i either need a new MOBO thats fm2+ to fit in my build or a new CPU and MOBO and GPU but i'm not quite sure i can get a MOBO and CPU for less than $200 if i get the 1070. I was also thinking about the 980 ti since its only a couple frames lower in most games than the 1070 and that's usually playing at ultra settings which i may or may not do. PLEASE PLEASE PLEASE HELP!!! AM TRYING TO GET THIS WEEKEND IF POSSIBLE.
In summary I need a fm2+  MOBO and a graphics card and i have about $700 to use. I just wanna play my games at 60Fps or around that (GTAV, ass. creed, Bioshock infinite, fallout 4, fallout 3,the witcher 3, shadow of mordor, dirty bomb, and etc) i also want to be able to edit videos and such. any recommendations on a ATX fm2+ MOBO ( or FX CPU + MOBO combo deal) and a graphics card that can handle what i said. Please and thank you <3
Also the possible $1100 is if i wait 2 more weeks til my next check which i can bare if its needed but if i dont then i wont because i also need to buy a car in the coming months so i'm saving for that too.
Could you please edit your post and make it a little more comprehensible?
I don't understand your question.
Buy a titan x!!!!
"Always forgive your enemies, but never forget their names." John F. Kennedy
"Daddy is going on a dangerous mission to shoot his employees." Linus Sebastian
"It's soft, but in a good way, kinda like typing on boobs." Luke Lafreniere
You might want to reask the question using punctuation. Are you scared of periods?
Honestly, with that kind of budget I'd just start over. You can't really upgrade on the platform you're on, nor would I recommend it even if you could. AMD's current CPU's are too old.
i5, motherboard, RAM, and mid range videocard should be doable with your budget, especially if you factor in what you can sell the old stuff for.
Do you just play at 1080p on a 60hz monitor? Or are you running something better?
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yes i just play 1080p on a 60hz monitor. I've realized my mistakes my apologies. Also i know i'm pretty much starting over i just don't know what to get and if i can get it for $700.
The i5 i was looking at were going for quite a bit do you have any specific i5 suggestions? and i have an 8gb stick of RAM already. I just wanna know how much the CPU and Motherboard will leave me for my graphics card so i can know to either wait til my next paycheck or just get it today.
Did the summary help?
he's trying to get MOBO that has enough clearance for his MOBO because his current MOBO doesn't really have enough space to fit a MOBO
Try this one
http://pcpartpicker.com/list/rTTmr7
Or this one
http://pcpartpicker.com/list/nmh9r7
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
Try this one
Or this one
Ah thanks.
I agree with @DXMember's post: those are good budget builds.
