I need help with Python.
Go to solution Solved by Enderman,
just like in regular math you can do a<b or a>b
so if answer>5 then it should return 1
figure the other one out
Hello!
I cannot figure how to set this up to come out right. Can anyone help?
  1. On line 2, fill in the if statement to check if answer is greater than 5.
  2. On line 4, fill in the elif so that the function outputs -1 if answer is less than 5.
def greater_less_equal_5(answer):
    if ____:
        return 1
    elif ____:
        return -1
    else:
        return 0
print greater_less_equal_5(4)
print greater_less_equal_5(5)
print greater_less_equal_5(6)
Thanks,
Jerahmy
https://linustechtips.com/topic/558884-i-need-help-with-python/
https://linustechtips.com/topic/558884-i-need-help-with-python/#findComment-7354101
I dont do Python myself, so I don't know the syntax ... but this is kinda what you want:
//Greater than 5
if (answer > 5)
	//Answer is greater than 5, so it should return 1?
	return 1;
//Less than 5
if (answer < 5)
	//Answer is less than 5, so it should return -1?
	return -1;
//The else statement you have which will only get triggered if the answer is 5
else
	return 0;
I kinda made this in a Javascript/C# kinda way so you gotta translate it into Python syntax yourself
https://linustechtips.com/topic/558884-i-need-help-with-python/#findComment-7354124
