Posted January 20, 2016 Just interested in what people think is the hardest part of building a pc Personally I think the the front panel connectors for the power led and power and reset buttons are the hardest because I have large fat hands Just because something doesn’t do what you planned it to do doesn’t mean it’s useless. – Thomas Edison Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 Popular Post The hardest part is being able to afford a build. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 Installing your motherboard when you forget to take out the covers for the HDMI so it doesn't fit in... Nothing about building a PC is particularly hard if you have the knowledge. CPU: Intel 3570 GPUs: Nvidia GTX 660Ti Case: Fractal design Define R4 Storage: 1TB WD Caviar Black & 240GB Hyper X 3k SSD Sound: Custom One Pros Keyboard: Ducky Shine 4 Mouse: Logitech G500 Ubisoft's Anthem: http://linustechtips.com/main/topic/249540-my-ubisoft-song/ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 Depends on the build really. If you're building in a really small case, then cable management can be a massive pain. If you're doing custom work, then that is often the hardest part. In general, I'd agree to front panel connectors being the easiest to mess up. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 For me it's installing the CPU (I get slightly shaky) Archangel (Desktop) CPU: i5 4590 GPU:Asus R9 280 3GB RAM:HyperX Beast 2x4GBPSU:SeaSonic S12G 750W Mobo:GA-H97m-HD3 Case:CM Silencio 650 Storage:1 TB WD RedCelestial (Laptop 1) CPU:i7 4720HQ GPU:GTX 860M 4GB RAM:2x4GB SK Hynix DDR3Storage: 250GB 850 EVO Model:Lenovo Y50-70Seraph (Laptop 2) CPU:i7 6700HQ GPU:GTX 970M 3GB RAM:2x8GB DDR4Storage: 256GB Samsung 951 + 1TB Toshiba HDD Model:Asus GL502VTWindows 10 is now MSX! - http://linustechtips.com/main/topic/440190-can-we-start-calling-windows-10/page-6 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 Installing the Ram, I get confused and try and putting it in the wrong way. But I almost instantly know what I am doing wrong and I correct myself. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 the hardest part is mounting a bequiet cooler, if you got any other brand of cooler, the hardest part is probably getting your cables decent. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted January 20, 2016 The hardest parts is hoping that Australia Post deliveries your item. Magical Pineapples
