Best way to compress files from another machine?
Solved by Britishblue,
2 hours ago, Electronics Wizardy said:Does your user have permissions to the share and folder beng shared?
Try rebooting that desktop if you have't already.
Make sure to use the samba password as it can be different.
You can also try enabling guest access and see if that works.
Can you post your smb.conf file for the share?
Somehow fixed it by doing "net stop workstation /y"
then "net start workstation" on my windows computer.
Thanks for your help
