Dumbest case I've seen in years
tkitch
Not the dumbest case I've ever seen (cuz there have been some truly atrocious ones) but...  this is pretty terrible
https://www.marsgaming.eu/en/cases/mcorb-premium-gaming-circular-tower_mcorb
Air Cooler with the weirdest airflow pattern ever, or you can do up to 3x 120mm Rads for the most annoying 360mm watercooling ever!
MCORB PREMIUM GAMING CIRCULAR TOWER
It looks like Iron Man's Arc Reactor
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
Support for massive GPUs and coolers, 1x2.5" and 2x3.5" (which means potentially 5x2.5"), absolutely huge but airflow is going to be godmode in that thing. Disregarding price, which I'm guessing is in the $200-300 range, if you enjoy or can at least live with the bizarro aesthetic, that's actually a pretty solid case in a weird body.
I love the name "McOrb" btw
Aerocool DS are the best fans you've never tried.
if you think "big and lots of fans" automatically means awesome airflow?
Go look up the GN Video "12 Fans, No Chill"
big ol honkin' case, 12 included case fans, and shitall for airflow
🤔ill have like 40+ fans in my build...🤷‍♂️
case is not that bad but most likey cost more then its worth thow. its an air flow case not a water cooling case but some one will water cool in it.
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
1 minute ago, Needfuldoer said:
Not available in blue because they'd get sued by Sega.
Funny enough I saw one of these in blue the other day when hitting a store - it was hosting Sonic-themed build.
As others already pointed out, from a fuild dynamic viewpoint the airflow is gonna be a mess. Way too many random openings, and the multiple fan orientations will cause a hell of a turbulence.
The way the fans are set up in the picture is pretty stupid. Have hot GPU exhaust pulled through the 120mm CPU radiator. It looks like there are 9 fan mounts. Doesn't look like there's anywhere to put a rad bigger than 120mm, so I'd go with a big dual-tower air cooler if I had a CPU that required me to channel the power of the north pole to keep it under 90C. You could balance out those 9 fan curves really easily to keep it nice and cool in there, including having some of them shut down when you don't need full-blast cooling. Added bonus is that with so many fans, there are basically dedicated intake/exhaust for each component.
It looks ridiculous, it probably costs way too much and it's not for me, but I still think that would be a solid choice for a lot of use cases. If you want a truly dumb case, go to Amazon and search "cool pc case", then look at all the $70-120 ultra-tight mid-towers that are basically a sheet of metal with slabs of tempered glass on the front and side, one 120mm exhaust and an "intake" that consists of a 0.5" wide, 1" long slit under the front panel. But it's got tons of potential for high-end CPUs because it can support a CPU cooler of up to 155mm, and what CPU can't be cooled by a Vetroo V5, right?
I just can't unsee the cheap happy meals toy look now ~
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Impressive.
Let's see the AC input for the power supply.
Caroline doesn't need to hear all this, she's a highly trained professional.
I like it. At least it isn't yet another boring box.
Main system: i9-7980XE, Asus X299 TUF mark 2, Noctua D15, Corsair Vengeance Pro 3200 3x 16GB 2R, RTX 3070, NZXT E850, GameMax Abyss, Samsung 980 Pro 2TB, Acer Predator XB241YU 24" 1440p 144Hz G-Sync + HP LP2475w 24" 1200p 60Hz wide gamut
1 hour ago, Caroline said:
Impressive.
looks like a 90 degree cable going out the bottom between the fans down there
These fans cancel each other
Yeah it looks too close to sonic
System Specs:
CPU: AMD Ryzen 7 5800x 8-Core Processor
Memory: 32 GB G.Skill Trident Z DDR4
SSD: WD_BLACK SN770 1TB
GPU: Nvidia GeForce RTX 3060 12G oc
Motherboard: Asus Prime B-450 A2
Case: MuseTex k2 Mid Tower
Monitor 1: Samsung SyncMaster S27D360
Monitor 2: Samsung Syncmaster S27B350
Keyboard: Razer Onata
Mouse: Razer Viper
Just hear me out guys.
Ditch the glass, mesh the side, make the entire case one huge ass blower with your PC inside.
  • 2 weeks later...
Those look like huge Beyblades.
