CPU cooler compatibility and fans recommendation
Go to solution Solved by filpo,
6 minutes ago, MiszS said:
but idk if there isn't a better alternative
for the value there isn't really
for performance there's the Lian Li P28's for $56 for three and they've got great CFM without that much noise
i'm wondering if only 1mm space left is ok?
yes, it's under the max cooler height
7 minutes ago, MiszS said:
I'm building a pc, with the H6 flow case, which has max 163mm cpu cooler height,
What's your budget? Country? Use case? gaming res?
I'm building a pc, with the H6 flow case, which has max 163mm cpu cooler height, and the ak620 digital which is 162mm, i'm wondering if only 1mm space left is ok? Another question is which fans are the best to get for the cooler (since the stock ones suck), i think about getting the arctic P12 PWM, but idk if there isn't a better alternative
Posted (edited)
Edited by filpo
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
doesn't rlly matter, because i know what i want for the rest of the build but here's a screenshot from my spreadsheet (no pcpartpicker in poland). I play on 1080p 360Hz
How many watts is that PSU? Instead of getting the Fan hub get the PST version of the P12 and then you can just daisy chain them
Which msi b650m motherboard?
Everything else looks good 👍
Current parts list
Is the thermalright thing this?
If so, its entirely not needed if you want to save some pocket change
H6 flow is a great choice
Is the AK620 digital a must? Are any of thermalrights coolers available to you or do you really want the digital screen included?
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
The PSU is 750W, i want the AK620 because it looks good, and the other cooler i wanted to get, deepcool assasin IV is too tall for the case, and has some weird fan noise. I Also chose the motherboard because it looks good, and is a pretty good value for the VRM and looks. I got the cpu contact frame because it's pretty cheap, but can slightly improve the temps, and gives me a peace of mind, especially if i upgrade to a more power hungry cpu in the future. The P12 PST fans are actually a good idea, only 50 cents more expensive so i might actually get them, but how would i go about chaining them, when they across the entire case? I also still would get the FAN hub, because i want to minimise the cables on the front
cable manage from the back. I've got a p12 pst and it's basically an extra fan header but on the end of the cable so you can chain them together
the cables won't go across the front, but you can if you want
Current parts list
That fair enough, if you want to get it, it isnt super expensive and has a few benefits, but i will say, for AM5 you wont see any change in temps
All the other yeah perfect, i know some people like certain aesthetics and the screen on the digital is a real fun quirk to have
All my fans' RGB, my GPU's RGB and my right angle 24pin's RGB are all daisy chained off each other, there are many ways of hiding and managing cables well
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Very nice cable management! Looks really good. Bruh?! Wth, did you have a left over fan from your 3D printer or something. Why?
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
that looks funny lol, didn't even notice
Shhhh, i contemplated painting it black but you cant see it when the tinted side panel is on and the RGB lights up everywhere but there 😋WhatsAppImage2024-03-29at3_54_20PM.thumb.jpeg.a5ec617200ebbc0cea340d7f1be6ee7d.jpeg
Thats it midday, it gets harder again to see at night
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
No i seen a couple tests done with small 40mm fans, having them on there stops the GPU circulating its own hot exhaust air, it only reduces temps by a handful of degrees but the fan is silent, tiny and easy to setup so why not, I have another one too just above the GPU backplate blowing up through the I/O shield/VRM heatsink, cools the VRMs slightly, i dont think ive seen my max VRM temps, under load, pass 35C
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
If youre curious about my fan placements this might explain better, you know what they say, a pictures worth a thousand words
WhatsAppImage2024-05-01at4_49.31PM(1).thumb.jpeg.385e5700a5a735df1c916bb236eefffd.jpeg
WhatsAppImage2024-05-01at4_49.31PM(2).thumb.jpeg.4eac0ec92b41851592eb72c174b19f87.jpegWhatsAppImage2024-05-01at4_49_32PM.thumb.jpeg.9977e17ca98f2e046c85578c44bd1fa9.jpeg
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
