How Bad Is Dust For PC Components?
Solved by wolfmcbeard,
I'll admit I only properly clean my machines including consoles maybe once a year, and while the dust get's thick, I've never had anything fry or damage stuff from dust and dog hair build up.
If It seems my machine gets hotter than it should, I'll clean it then.
Do it every couple of months if you want to keep things looking pretty and keep in mind stuff mentioned in the earlier posts regarding your own environment and unique dust situations.
