What is PageFile.sys? And how do I delete it?
Solved by LogicalDrm,
-> Moved to Windows
As said, don't delete it completely. You can make it much smaller, like max 8gigs or less. You know if its big enough when you start getting crashes that have no other reason. For example Adobe products use pagefile.
Also, Windows doesn't care where its located. If you have HDD, you can move whole pagefile onto that.
Featured Topics
shift8 ·
Posted in Networking0 -
dbzocchi ·
Posted in General Discussion0 -
Premoz1 ·
Posted in General Discussion3 -
2
2
Cheki ·
Posted in Troubleshooting2 -
5
3
5
play_circle_filled
Latest From ShortCircuit:
I tried 20 influencer foods, here are the best… and the worst…
