Help GPU Making White Shadow Trail
Solved by minibois,
-- Moved to Displays --
This is called 'ghosting', it has to do with the monitor not updating the pixels fast enough, which shows a 'ghost' of the cursor in the previous frame on screen.
As said above, check your monitor's settings. Sometimes this can be a certain mode (i.e. gaming mode, photo mode, etc. where one has better response time vs. the other having better colors) or a certain overdrive setting.
