Fractal Design Define 7 with cd rom fan configuration question
Solved by podkall,
3 minutes ago, jaslion said:Ah my bad misread.
Id still look for a meshcase as well due to poor airflow everything will have to run the fans faster tp cool thus be louder thus negate any noise cancelling from the case.
White mesh cases that might have enough whatever everything you need, but I didn't check: (and good airflow because they're mesh)
Case: Montech AIR 903 MAX ATX Mid Tower Case (kr1110.00 @ Proshop)
Case: Montech AIR 903 BASE ATX Mid Tower Case (kr1003.00 @ Proshop)
Case: Montech X3 Mesh ATX Mid Tower Case (kr722.00 @ Proshop)
Case: Fractal Design Pop XL Air ATX Full Tower Case (kr1538.00 @ Proshop)
