Why CPU IHS aren't made out of copper insteed of aluminum ?
Solved by Mateyyy,
It's nickel plated copper, both for Intel and AMD CPUs, as far as I'm aware.
Edit: Actually, to further comment on this -- if IHSes were made out of aluminium, you wouldn't be seeing people use liquid metal for the TIM on CPUs. Well, not that that's a very common use case for LM, but still, you can do it.
Thermal Grizzly does mention this as a valid use case for their Conductonaut TIM (which is liquid metal): https://www.thermal-grizzly.com/en/products/26-conductonaut-en
Additionally, as mentioned by @Electronics Wizardy above, if you were to lap the IHS on a modern CPU (which is common practice in the overclocking community), you'd eventually get through the nickel plating and the bare copper would be visible.
