12 Pin GPU Cable From Corsair - In the 3060Ti FE ?
venomx
1 minute ago, venomx said:
aesthetics
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
5 minutes ago, venomx said:
I have a 3060Ti FE which comes with a 8 pin to 12 pin connector.
If I buy a 12 pin connector from corsair ( removing the adapter completely ) would I gain any performance or is it purely aesthetics ?
https://www.corsair.com/uk/en/Categories/Products/Accessories-|-Parts/PC-Components/Power-Supplies/12-pin-GPU-Power-Cable/p/CP-8920274
no lmao, it is just bunch of wires worth 0.10$ connected together
Definitely not worth 19.99 Euro
Main: Intel i7-10700KF, RTX 3080 Ventus 3X OC, 16 GB 3900MHz CL15 B-Die, Windows 11 Pro
Third PC: Intel i5-10400F, RTX 2080 Super Gaming X Trio, 16GB 3000MHz Timitec, Windows 10 Pro
Second PC: Ryzen 7 2700, RTX 2070 Super STRIX, 16GB 3200MHz CL15, Windows 10 Pro
First PC: Intel i5-3570, GTX 1060 Windforce, 16GB G-Skill 1600MHz, Windows 10 Pro
Hmmm Laptop: Pentium M 1.6GHz, iGPU, 2 GB 800MHz DDR2, Windows 7 SP1
Just for looks.
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
its for looks
I was lucky as have a Seasonic PSU and they provided a free cable :)
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
Fair enough. I was asking because the adapter that came with it only has 6 pins on the side which goes into the GPU which is strange as on the GPU it has 12 pins
I have the 3060ti FE and 3070 FE and both have the same cable.
i think its like that as the GPU doesn't use that much power.
my new cable has 2x 8pin to 12pin (as the corsair one you have linked to) so all the pins are connected now.
not sure what difference it makes, possible better OC? as moer power connected to it
Folding Stats
SYSTEM SPEC
Thanks for the info. Are you using the exact one I posted ? Or just the same but a different brand ?
mines a seasonic one
Folding Stats
SYSTEM SPEC
Ok, no difference in FPS etc once you changed from the supplied adapter to the new cable you have ?
nothing changed.
I dont O/C ad cant in my small case so not sure if it would help with overclocking
Folding Stats
SYSTEM SPEC
Ah ok. I'll leave it be then. I don't plan on overlocking either.
Thing is the provided adapter should work fine, the other thing is you never plan on overclocking, it 'just happens'... ;)
But yeah the 3060ti doesn't have a huge power draw, it should be really ok. :)
-Scott Manley, 2021
Softwares used:
Corsair Link (Anime Edition)
MSI Afterburner
OpenRGB
Lively Wallpaper
OBS Studio
Shutter Encoder
Avidemux
FSResizer
Audacity
VLC
WMP
GIMP
HWiNFO64
Paint
3D Paint
GitHub Desktop
Superposition
Prime95
Aida64
GPUZ
CPUZ
Generic Logviewer
Yah thanks for the info . Wont waste my money then if there is no increase in performance.  I think the provided adapter looks fine
  • 2 weeks later...
I've changed my setup now and want a tidier looking cable.
Before I buy, have you tried your 12-pin cable in the 3060ti fe ?
no only in my 3070. cant see why it wont work in the 3060ti FE
Folding Stats
SYSTEM SPEC
