Corsair RMx or Fractal Desion ION+
Solved by Ankh Tech,
10 minutes ago, Mateyyy said:They're both good, though the RMx seems to edge out the Ion+ overall. Here's Aris' reviews of both units:
https://www.tomshardware.com/reviews/corsair-rm750x-v2-psu,5585.html
https://www.tomshardware.com/reviews/fractal-design-ion-platinum-760w-power-supply-review
I don't really get what you mean here, to be perfectly honest.
What components will you be powering?
he means the extra 4 pin for the cpu, The rm750x is a tad bette, the ion is more efficient, if you oc get the rm750x, even if you plan to oc get the rm750x, to not buy two psu.
