Is this 6 pin to 8 pin pcie connector usable in a custom pc build?
9 hours ago, Windows7ge said:Are you asking why I think it would be fine? 1. Sufficient wire gauge, 2. Quality of manufacturing.
I'm referring to a 400W PSU with only a single 6-pin. You're invalidating your own argument if you tell me it's fine to pull 150W from it.
Simple, read the print on the side of the individual wires. 18AWG x6 wires on an 8-pin cable with 2x jumping off 2 grounds (150W), 18AWG on x6 wires on a 6-pin cable (magically can only supply 1/2 the power). Do explain that. The 6-pin/8-pin standard is pointless if you know what you're doing (which to be honest most people don't so that's where the "buffer" comes in you were discussing - it makes sense why it was made but physically it's not valid).
Thank you. That's all I was looking to get across.
I gave one example but agreed 95%+ of the time the situation wouldn't come to pass.
Agreed.
I will use a dual 6 pin to 8 pin, thanks for the help.
