Need The Best Air Flow Case For This Build
ooqw
Go to solution Solved by ooqw,
3 minutes ago, TVwazhere said:
Mmmmm no thanks.
@ooqw, when you say "RGB - AESTETICS - TEMPERED GLASS NOT NEEDED!", are oyu telling us you want RGB but dont need TG, or neither of those are required? Additionally, what is your case budget?
I do not want any of those. If its a better buy to have rgb in it, then I would get it. However, it will most likely not be shown. I have updated the list. I now have the NH- D15 and the meshify-C case with i7-10700k instead of the i9.
https://pcpartpicker.com/user/opqw/saved/R4QTJx
That is my current pick! Please provide the best case for this build. I am looking for something that has high airflow. I do not yet have a cpu cooler. Feel free to provide an AIO or air-cooler that you think works best for the build.
First of all
Please don't get a steel legend
Terrible board with terrible power limits
Get an a pro or a vision G or a tomahawk
Second of all
Meshify c
P400a
P300a
Phone: Pixel 3a (Purple-ish).
Build Log:
Just now, BlueScope819 said:
can help you with the case selection
I'm sure @TVwazhere will do a way better job ;)
Build Log:
3 minutes ago, BlueScope819 said:
I can't help but notice you are buying a 10900k with a 2070S. I would recommend either the i7 10700k or the 3700x if you do anything with your computer besides gaming, and trade the savings for a 2080S. For the cooler, I would recommend the Noctua NH-U12s. I'm sure @TofuHaroto can help you with the case selection.
That is a great idea. Ill look into the i7-10700k and look into getting the 2080s instead of the 2070s
2 minutes ago, BlueScope819 said:
Okay @TVwazhere, I'll do the honors for you.
Mmmmm no thanks.
CPU i7-4790k    Motherboard Gigabyte Z97N-WIFI    RAM G.Skill Sniper DDR3 1866mhz    GPU EVGA GTX1080Ti FTW3    Case Corsair 380T
Storage Samsung EVO 250GB, Samsung EVO 1TB, WD Black 3TB, WD Black 5TB    PSU Corsair CX750M    Cooling Cryorig H7 with NF-A12x25
Mmmmm no thanks.
Just now, ooqw said:
My room is can get quite dusty.
So it's a high airflow case AND a room cleaner, if you know how to use it properly. 🤪
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
silly but ill definitely consider it NOT
13 minutes ago, TofuHaroto said:
First of all
Second of all
Meshify c
P400a
P300a
https://pcpartpicker.com/product/bLK2FT/msi-mag-z490-tomahawk-atx-lga1200-motherboard-mag-z490-tomahawk ??
This is a tomahawk, obviously idk which one you'd be thinking of. What other mobos can fit?
If your talking about size then the cases I recommended are all atx meaning that the tomahawk would fit.
Build Log:
Alright this one works well then.
I can help with the CPU cooler. The Deepcool Assassin III is cheaper ($91 USD) and is the best air cooler on the market right now
MAIN PC:
CPU: Intel® Core™ i9-9900K Processor  Motherboard: Gigabyte Z390 Aorus Pro Wifi  CPU Cooler: Scythe Fuma 2  GPU: EVGA RTX 3080 FTW3 Ultra  RAM: Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red  Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
SECONDARY PC:
CPU: Intel® Core™ i3-9100F Processor  Motherboard: ASRock Z390 Phantom Gaming 4-CB  CPU Cooler: Arctic Alpine 12 CO  GPU: EVGA RTX 3060 XC RAM: ADATA XPG 16GB (2x8GB) 2400Mhz CL16
Case: CyberpowerPC Onyxia  PSU: ATNG ATA-B 800w 80 Plus Bronze  Storage: 500GB Samsung 850 EVO + 2TB Seagate FireCuda SSHD 5400RPM    OS: Windows 10 Home
Former parts that I've used: Acer XG270HU, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti
That's a good pairing.
My F@H rig in my Thermaltake Level 10 GT dust filters in the basement have stopped picking up any dust, and it's been six months!!!
