Can 500 watts be enough for ryzen 5 3600 and rx 570 8gb
otic
Since I already have a ryzen 5 3600 and 500 watts power supply I would like to know if enough for rx 570
As long as its 80 plus rating it should be fine, I wouldn’t trust a cheap Chinesium unit.
Quote me or @TwilightRavens if you want me to see your reply. I may go inactive for a long time from time to time because I forget how to socialize, but I will be back... eventually.
Main Gaming PC
AMD Ryzen 9 5950X || AsRock X570 Taichi || G.Skill TridentZ Neo DDR4 3600MHz 2 x 16GB C16 1.35v || AMD Wraith Prism || Phanteks Enthoo Pro E-ATX || Gigabyte RTX 3080 Ti Gaming OC || Samsung 970 Evo 250GB NVME SSD & Samsung 980 Pro 2TB NVME & Crucial 960GB SATA III SSD || EVGA Supernova 750W Platinum PQ || Windows 10 Pro 22H2 x64 || Gigabyte M27Q 27" 170Hz 1440P & Acer 21.5” 1080p 75hz IPS || Logitech G213 Prodigy || Logitech G502 Hero
Laptop
AMD Ryzen 5 4600H with RadeonGraphics || ASUS TUF A15 ||  DDR4 3200MHz 2 x 8GB C22 1.2v || ASUS GeForce GTX 1650 4G GDDR6 || 512GB NVME M.2 SSD  ||  Ubuntu 22.04.1 (Jammy Jellyfish)
4 minutes ago, TwilightRavens said:
80 plus rating
This rating is completely useless when it comes to quality. Rates efficiency, still might be shit. Plenty of horrible psu's have 80 plus rating.
Just now, otic said:
500 Watt 80 Plus ATX
Yeah but what's the brand and model of the psu? This information is useless as we still don't know what exact psu it is.
Useless info, model name is needed.
If there’s no overclocking at least a name brand 80+ unit will work, if overclocking then yes higher rating the better. But for stock out of box performance an 80+ unit will suffice. That said don’t get a unit from like zongdongchong (made up a name for sake of this) for $15 when instead at least something from a reputable brand like evga or corsair.
Main Gaming PC
Laptop
1 minute ago, otic said:
Oh brand evga @jaslion
Yes but what's the model? They have 20 or so 500w 80 plus psu's. Is it a bq, a supernova, a br, a ...? We need to know that.
Oh nvm I think I found out thanks tho
Just now, TwilightRavens said:
If there’s no overclocking at least a name brand 80+ unit will work, if overclocking then yes higher rating the better. But for stock out of box performance an 80+ unit will suffice. That said don’t get a unit for like zongdongchong for $15 when instead at least something from a reputable brand.
This is false. There are plenty of name brand 80+ psu's that are just bad.
We want to help you so could you please give us the information we need. There are psu's from evga that fall under your listed specs that will not safely handle a rx570
Been running an 80+ rating thermaltake unit for about 7 years in my home server and its fine thus far.
Main Gaming PC
Laptop
Lucky you then.
Yes that's because it's a good quality psu most likely. Now take like a vs 650 and put a ryzen 3600 + rx 5700 on it and watch if fail in 6 months. Even tho a good 550w psu or even 450w could easily handle that.
There are still good 80+ units that exist, if you do your research they really aren’t rocket science to locate. I’m not claiming all are good nor is it the best idea to get one, but to write them all off without so much as doing simple research is just daft. You clearly misread my post.
that said, yes bronze or better is a smart decision, however if you actually read reviews on a unit before purchasing do that. Most reputable reviewers will use a psu load tester, and if it fails those tests I would stay well away from it. EVGA’s BR series for example, trash psu from a reputable brand.
Main Gaming PC
Laptop
Your post was very poorly worded then, you said that as long as it's 80 plus and from a reputable brand it will be fine, which is not true.
Edited by nox_
That means nothing
 A model is what matters
There are 80 plus platinum PSUs that suck
Phone: Pixel 3a (Purple-ish).
Build Log:
36 minutes ago, nox_ said:
Your post was very poorly worded then, you said that as long as it's 80 plus and a reputable brand it will be fine, which is not true.
totally true 80+ doesn't equal to a good PSU
Everyone, Creator初音ミク Hatsune Miku Google commercial.
Cameras: Main: Canon 70D - Secondary: Panasonic GX85 - Spare: Samsung ST68. - Action cams: GoPro Hero+, Akaso EK7000pro
Dead cameras: Nikion s4000, Canon XTi
Pc's
Dell optiplex 5050 (main) - i5-6500- 20GB ram -500gb samsung 970 evo  500gb WD blue HDD - dvd r/w
HP compaq 8300 prebuilt - Intel i5-3470 - 8GB ram - 500GB HDD - bluray drive
old windows 7 gaming desktop - Intel i5 2400 - lenovo CIH61M V:1.0 - 4GB ram - 1TB HDD - dual DVD r/w
main laptop acer e5 15 - Intel i3 7th gen - 16GB ram - 1TB HDD - dvd drive
school laptop lenovo 300e chromebook 2nd gen - Intel celeron - 4GB ram - 32GB SSD
audio mac- 2017 apple macbook air A1466 EMC 3178
Any questions? pm me.
#Muricaparrotgang
  • 2 years later...
I found about this the hard way. I got the 750w Huntkey GS750 80white. I have a Ryzen 5 2600 + RX 570 4GB + 2x8 GB DDR4. For two whole years, my PC had frequent crashing, and freezing. It was fairly hard to know which part was malfunctioning due to NOT seeing a Blue Screen. Event Viewer logs are non-existent.
Tried changing the mobo, RAM, GPU and HDD. I didn't even suspect the PSU cuz back then I bought it brand new. But when I was so pissed-off after suffering a system crash for the 1000th time (not exactly a thousand but you get the picture), I bit the bullet and bought a 650w Seasonic S12III Evo 80 Bronze.
Didn't suffer from a crash or freeze after that. Been using it for more than 5 months already without a hitch. Back when I haven't replaced my PSU, it would freeze or crash at least once per day.
Well, that's a pretty bad model. One of the worst Seasonics in years.
Yeah which one. Thermaltake has garbage tier stuff that is known for failiure when pushed even a little and they also have excellent units.
Just because you have used for example their 450 smart 80+ whitr for 5 years with a 2080 doesnt invalidated the MANY others whos pc was killed by it
