1 minute ago, Cosco said:
Quick question, how to people build functional PC's under water in a fish tank?
It's not "water" and is normally submerged in mineral oil or some other kind of non-conductive fluid.
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599040
Thats super weird, my friend tried to make one and he put water in the tank and ruined his 2070
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599047
That would ruin it alright.  Mineral oil has its issues too.
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599051
That’s pure stupidity, water is conductive, and corrosive, if you try to start up a wet pc, or a pc submerged in water, you will kill it.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599060
2 minutes ago, WI-FIultrasnoop said:
Why do you want to build a PC submerged in a fluid of some kind?
Mineral oil PC's have impressively low temps (lower than conventional water cooling), at the expense of high maintenance.
Brands I wholeheartedly reccomend (though do have flawed products): Apple, Razer, Corsair, Asus, Gigabyte, bequiet!, Noctua, Fractal, GSkill (RAM only)
Wall Of Fame (Informative people/People I like): @Glenwing @DrMacintosh @Schnoz @TempestCatto @LogicalDrm @Dan Castellaneta
Useful threads:
How To Make Your Own Cloud Storage
Guide to Display Cables/Adapters
PSU Tier List (Latest)-
Main PC: See spoiler tag
Laptop: 2020 iPad Pro 12.9" with Magic Keyboard
PCPartPicker Part List: https://pcpartpicker.com/list/gKh8zN
CPU: AMD Ryzen 9 3900X 3.8 GHz 12-Core OEM/Tray Processor  (Purchased For $419.99)
Motherboard: Asus ROG Crosshair VIII Formula ATX AM4 Motherboard  (Purchased For $356.99)
Memory: G.Skill Trident Z RGB 32 GB (2 x 16 GB) DDR4-3000 Memory  (Purchased For $130.00)
Storage: Kingston Predator 240 GB M.2-2280 NVME Solid State Drive  (Purchased For $40.00)
Storage: Crucial MX300 1.05 TB 2.5" Solid State Drive  (Purchased For $100.00)
Storage: Western Digital Red 8 TB 3.5" 5400RPM Internal Hard Drive  (Purchased For $180.00)
Video Card: Gigabyte GeForce RTX 2070 8 GB WINDFORCE Video Card  (Purchased For $370.00)
Case: Fractal Design Define R6 USB-C ATX Mid Tower Case  (Purchased For $100.00)
Power Supply: Corsair RMi 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For $120.00)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  (Purchased For $75.00)
Total: $1891.98
Generated by PCPartPicker 2020-04-02 19:59 EDT-0400
身のなわたしはる果てぞ  悲しわたしはかりけるわたしは
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599065
The theory is it’s totally silent all-over cooling that lasts forever.  The problem is thermodynamics is a harsh mistress.  it isn’t totally silent and it doesn’t last forever and on top of hat 5 gallons of mineral oil is a huge awful mess.  Mineral oil PCs are rarely done more than once.   I remember one attempt at an industrial application.  It almost worked except upgrades turned out to be incredibly brutal and took all the advantage away plus some.
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599067
It looks cool, not much of a performance increase if any
AMD blackout rig
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599069
1 hour ago, Cosco said:
he somehow got his money back by saying he "sneezed" on it so the store would accept his refund
I don’t know if I’m more shocked that someone used this excuse, or that it worked.
AMD Ryzen 5900X
T-Force Vulcan Z 3200mhz 2x32GB
EVGA RTX 3060 Ti XC
MSI B450 Gaming Plus
Cooler Master Hyper 212 Evo
Samsung 970 EVO Plus 2TB
WD 5400RPM 2TB
EVGA G3 750W
Corsair Carbide 300R
Arctic Fans 140mm x4 120mm x 1
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599282
31 minutes ago, Cosco said:
yeah you see hes not a friend hes more then like an acquaintance and i'm confused myself
He must be lousy at logic and critical thinking, but great at BS and screwing over other people.  Everybody’s good at something..  Seen that particular skill set somewhere recently....
https://linustechtips.com/topic/1194084-fish-tank-pc/#findComment-13599913
