CPU Stuck at 0,78GHz (HELP!)
Tsu
Go to solution Solved by unclewebb,
This problem is common and rarely has anything to do with the power supply.  Intel XTU does not report this problem correctly.  It shows thermal throttling even though the CPU temperature is just fine.
Try running ThrottleStop instead.  Open up the Limit Reasons window and you will likely see the real reason your CPU is throttling.  BD PROCHOT will be lit up in red.
BD PROCHOT stands for bi-directional processor hot.  This allows other sensors on the motherboard to send a throttling signal to the CPU.  When one of these sensors goes bad, it will constantly send a throttling signal.  On the main screen of ThrottleStop you can clear the BD PROCHOT box so your CPU will stop listening to these fake throttling signals and then it will be able to run at its full rated speed.
If this fixes things, you can either replace the motherboard or just run ThrottleStop.  It is a simple solution for this problem.
I recently upgraded my CPU fan and ram the pc wouldn't boot and i needed to rebuild the pc 3 times over, once it booted and had a blue screen for not having enough power but after a few rebuilds it started to boot in windows. When booted into windows the CPU is stuck 0,78GHz and not 3,8GHz. In IETU (Intel extreme tuning utility) it says it's thermal throttling i have a ss here: 003150cc2abcc0ec0f126fce1348f906.png
https://gyazo.com/003150cc2abcc0ec0f126fce1348f906
I have an INTEL i5-8400
Also i think this might be a PSU issue any thought's?
Also this is what i upgraded:
Intel stock cooler -> Cryorig H7
8gb ram -> 24gb ram
did you forget to plug your cpu cooler into mobo? something is wrong with your cooler
Try going back to 8gbs of ram. Does that make a difference? Maybe the memory training is too much.
Things I do:
Upgrade Computers
Build Computers
Disassemble Computers
My System:
MSI GS65 Stealth
CPU - Intel Core i7-8750H
Memory - 16GB DDR4
Graphics Card - NVIDIA GeForce GTX 1660 Ti
Storage - 512 GB SSD
Operating System - Windows 10 Home
Headset - Turtle Beach Stealth 420X+
Yes, CPU cooler is not mounted properly, no thermal paste, etc etc etc.
You have a heat issue, look into your heat management (ie. CPU cooler).
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
Is there a reason it would?
OnePlus:
Other Tech:
No the cooler plug is in the cooler i have checked this 3 times.
Depending on the CPU memory training may throttle the cpu. Which would mean your cpu would be cheap af.
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
What CPU do you have?
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
You do see the Thermal Throttling status, correct?   He  needs to fix his cooling issue before worrying about RAM settings/training.
OnePlus:
Other Tech:
Ok. It would be nice to know what CPU he has.
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
I have a i5-8400 intel
Ok. One second.
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
i don't think thats the issue it looks fine from here and it has well enough paste also it is on 30C why would it thermal trottle
No idea why it would thermal throttle.  Unless the diagnostic is lying to you... it's thermal throttling.
Remount the CPU Cooler. I know you want to think you did it right but obviously something is wrong, so whynot reseat it and verify?
"Looks good from here" isn't a way to go about this.
OnePlus:
Other Tech:
Bro i have rebuilt this PC too many times also when i say it looks good i can see the cpu and the cooler on it through the case
also i think this is a PSU issue
Gotcha.
PSU's are a common source of thermal throttling, correct.
/sarcasm
You do what you want, but we can only go by what the diagnostic says.
Hopefully you fix the issue, take care.
OnePlus:
Other Tech:
What PSU do you have? What voltage is the CPU set to recieve?
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
I have a shit HP 500w bronze and i think it might have failed on me
There is your answer.
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
So it might be the PSU?
If it’s bad than most likely.
Things I do:
Upgrade Computers
Build Computers
My System:
MSI GS65 Stealth
Memory - 16GB DDR4
TDP 6W, clearly not getting the juice...
Edited by wkdpaul
Cleanup
Check the Power Management settings, maybe it's configured on Minimal / Power saving something... you can force processors to stay below some threshold ex:
* thread cleaned *
As per the Community Standards, trolling isn't allowed.
If you need help with your forum account, please use the Forum Support form !
