old seasonic m12 600w psu and rtx2060 super question
aygung
hello everybody,
i have this old seasonic m12 600w psu sitting around. it's 13 years old and I used it for a nice 6 years without any problems (even when I was into computers and did overclocking with a Q9550. it's all in the past now.) and then this pc got retired. money is a very big issue so I will definitely want to go with this psu instead of buying a new one if I can...
I am planning to build a new budget pc for 3d design and cpu/gpu rendering.
ryzen 9 3900x and a rtx 2060 super. (msi rtx 2060 super VENTUS GP)
all the psu calculators show smth around 450-500w for this rig.
I can not find an answer to this question on the internet:
because this psu is very old, would it be compatible with a rtx 2060 super?
and since I will do no overclocking I am guessing 600w would be more than enough.
*(back in the day I was using geforce gtx460 and an overclocked intel q9550 with this psu without problems.)
*(i live in Turkey, so even if you may have some nice alternatives to this psu with low prices, it most probably is not available here but please advice if you have a recommendation. I will look into it.)
thanks in advance for good advices.  please do not bother coming to say only yes or no if you don't have a point.
Don't get me wrong, but if you can afford a 3900X and a 2060 Super, then you should be able to afford saving a little more and buying a new PSU. You don't even need anything super expensive, a TX550M from Corsair or even a CX will do, but you never want to cheap out on the PSU, especially on a high-end system. The M12 PSUs weren't good even when they launched, so it being that old can only make matters worse. At least that's my take on it.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
You're spending a good amount of money on your rig, I would buy a new 600W PSU (at least bronze rated).
Callin ryzen 9 3900x and rtx 2060 super budget. Man plz you are spendin atleast 1500 dollars to that pc. Save some more on psu. You could cheap out whit buying cheaper rtx 2060 model
QUOTE ME  FOR ANSWER.
Main PC:
|Ryzen 7 3700x, OC to 4.2ghz @1.3V, 67C, or 4.4ghz @1.456V, 87C || Asus strix 5700 XT, +50 core, +50 memory, +50 power (not a great overclocker) || Asus Strix b550-A || G.skill trident Z Neo rgb 32gb 3600mhz cl16-19-19-19-39, oc to 3733mhz with the same timings || Cooler Master ml360 RGB AIO || Phanteks P500A Digital || Thermaltake ToughPower grand RGB750w 80+gold || Samsung 850 250gb and Adata SX 6000 Lite 500gb || Toshiba 5400rpm 1tb || Asus Rog Theta 7.1 || Asus Rog claymore || Asus Gladius 2 origin gaming mouse || Monitor 1 Asus 1080p 144hz || Monitor 2 AOC 1080p 75hz ||
Test Rig.
Ryzen 5 3400G || Gigabyte b450 S2H || Hyper X fury 2x4gb 2666mhz cl 16 ||Stock cooler || Antec NX100 || Silverstone essential 400w || Transgend SSD 220s 480gb ||
Just Sold
| i3 9100F || Msi Gaming X gtx 1050 TI || MSI Z390 A-Pro || Kingston 1x16gb 2400mhz cl17 || Stock cooler || Kolink Horizon RGB || Corsair CV 550w || Pny CS900 120gb ||
Tier lists for building a PC.
Motherboard tier list. Tier A for overclocking 5950x. Tier B for overclocking 5900x, Tier C for overclocking 5800X. Tier D for overclocking 5600X. Tier F for 4/6 core Cpus at stock. Tier E avoid.
(Also case airflow matter or if you are using Downcraft air cooler)
Gpu tier list. Rtx 3000 and RX 6000 not included since not so many reviews. Tier S for Water cooling. Tier A and B for overcloking. Tier C stock and Tier D avoid.
( You can overclock Tier C just fine, but it can get very loud, that is why it is not recommended for overclocking, same with tier D)
Psu tier List. Tier A for Rtx 3000, Vega and RX 6000. Tier B For anything else. Tier C cheap/IGPU. Tier D and E avoid.
(RTX 3000/ RX 6000 Might run just fine with higher wattage tier B unit, Rtx 3070 runs fine with tier B units)
Cpu cooler tier list. Tier 1&2 for power hungry Cpus with Overclock. Tier 3&4 for overclocking Ryzen 3,5,7 or lower power Intel Cpus. Tier 5 for overclocking low end Cpus or 4/6 core Ryzen. Tier 6&7 for stock. Tier 8&9 Ryzen stock cooler performance. Do not waste your money!
Storage tier List. Tier A for Moving files/  OS. Tier B for OS/Games. Tier C for games. Tier D budget Pcs. Tier E if on sale not the worst but not good.
(With a grain of salt, I use tier C for OS myself)
Case Tier List. Work In Progress. Most Phanteks airflow series cases already done!
Ask me anything :)
that's because the design that this PSU uses was much more relevant back then. aside from the modern things like sleep states and protections and whatever, this PSU is not independently regulated, which means its voltage delivery is much more suitable for old components instead of new components.
Under NO circumstances would I pair a 13 year old USED PSU with a $500 CPU. Just buy a 1660 super instead and used the saved cash for a new PSU that's actually good.
Primary PC:
That PSU was built in 2007.
If you can't be bothered to buy a new PSU, you shouldn't be buying an RTX2060.
What does that even mean?
Like gimme a circuit design on both ends and explain why this even matters.
It doesn't need a circuit design. I'm not the one to explicitly break down why group regulated power supplies can go out of spec, but if you disagree then hopefully you'd have your own explanation as to why.
I don't mean that the PSU is non functional, but it's well understood that group reg was designed for components that did not use the 12v rail nearly as much, especially compared to 5v, which was a long time ago.
Primary PC:
I'm not disagreeing with what you're saying. I'm asking you to explain
If a circuit design comparison isn't needed, that's fine, but saying "it's well understood..." doesn't explain the above.
Usually I link to the piece that @LukeSavenije wrote about "why not to buy a group regulated PSU in 2019 and on" since it's not really easy to abridge and it's an easy read.
But of course not really everyone wants to read a wall of text, they're often cool with "it's too old"
Primary PC:
1 minute ago, LukeSavenije said:
since @Fasauceome summoned me, have fun
The 10 link limit is just such a shame
Primary PC:
thank you everyone for the comments. as i see i should get a new psu. thanks for the explanations. it helped.
It is independently regulated.
So many posts in this thread wasted on debating a false assumption...
I think they're confusing lack of DC to DC for the +3.3V and +5V as group regulation.
that's... a weird config they did there, but it looks kinda like it?
i didn't check beforehand, but the conclusion ends up being the same
it's a psu from 2007, it's 2020, time to replace that thing
