Motherboards won’t display video output
lachietg
I have 3 gigabyte motherboards and none of them are working, I have 3 different video cards  5 cpus and 5 ram sticks and I have tried all different combinations and I can’t get any of them to work
they are all lga 775 boards with ddr2 ram (a bit old I know)
and help would be  appreciated :)
edit:the motherboards are
https://www.gigabyte.com/Motherboard/GA-8I945P-G-RH-rev-1x/
https://www.gigabyte.com/Motherboard/GA-965P-DS3-rev-10
https://www.gigabyte.com/Motherboard/GA-P31-DS3L-rev-1x
gpus:
https://www.gigabyte.com/Graphics-Card/GV-N98TGR-512I-rev-21
https://www.gigabyte.com/au/Graphics-Card/GV-NX84S512HP
https://www.gigabyte.com/au/Graphics-Card/GV-N750OC-1GI
Define “work” to start.
Well of the 3 I see only one of them seems to be plugged into anything.  I’m assuming that one doesn’t work either though.  That particular board is dual channel only I think considering the coloring of the ram ports.  You might be able to get it to work if you used 2 ram sticks in the yellow slots.  Also the PSU might not actually be functional.
yes, it is standerd ddr3 800
yes, i checked on motheboard website
yes , also i tested 3 differnt monitors just in case
and yes they are
and yes they are
and you of course wouldnt want us to know what cpu or gpu's you are trying correct? nor what motherboards these are
and yes they are
Was that a reply to my statement?  If so none of those things apply.
1: does the PSU actually work correctly?  There seems to be only one of those.  If it doesn’t work nothing else will.
2: dual channel memory slots.  They’re different colors on purpose.
3: haven’t even gotten to monitors yet.  “Doesn’t work means doesn’t power up”. If it does power up but doesn’t post that’s a different thing.
sorry man i was replying to the other guy but yes i have tested multiple psus
and 2 yes i did try 2 dimms in dual channel
and it powers on but doesnt display a video signal if thats what you are talking about
sorry they are
 9800 GT
8400 GS
and gtx 750 1gb
It was.  So we got power on.  You got a manual for those boards?  I see they’re all subtly different.  Argh.  The look identical in the photo.  Do any of them at lest have error light codes or a debug readout?
1 no, i unfortunately dont have a manual
2 no, but i  attached a pc speaker but it remained silent :(
You’re going to need 3 manuals.  One for each board.  They’re all different.  There’s going to be a debug procedure for each of them. All different.  Hopefully somewhat similar because it’s the same manufacturer.  No promises.  Manuals are downloadable from the gigabyte website.
figure out which one has the most feedback data (lights, sounds, whatever) and do that one first.  That there are no known good parts makes this a version of hell.  Every part is going to have to be tried in every combination on every board every time, and if all three possible parts of any one type are all bad, there’s no way to learn anything.  The evil is outlandish.  I’m glad I’m not doing it.
bright side is once we get one going there will be a way to find known good parts and it will go much faster.
yeah i will download the manuals ,as far as i know all of the graphics card are working so that rules out somthing :)
Have you tried resetting the CMOS?
Grammar and spelling is not indicative of intelligence/knowledge.  Not having the same opinion does not always mean lack of understanding.
Yep , again to no success
Looks like 2 of the 3 are missing the battery. Have you been transferring the same battery between all three? Have you tried replacing that?
Storage: WD 750 SE 500GB, WD 730 SE 1TB GPU: EVGA RTX 3070 Ti PSU: Corsair SF750 Case: Streacom DA2
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
Yes I have been transferring the battery, and I know the battery is good because it measured 2,7 volts in my multimeter
Try replacing it anyway. It's the only thing between the three that's constant.
This, they should be 3V's so at 2.7V it's likely dead,  in fact they can die reading 3V because of the type of cell they are and the load on them.
Alright
Oh alright I didn’t know that
