specs
i3 3240
gt 1030 gddr5
6gb of ram
1 ssd 2 hard drives
Oem Dell Mobo
240watt psu
So i play gta 5 alot and it runs great for the first 5-10 minutes then it goes from 45-50 fps to 20-30 fps And i can fricking figure out why
My settings are at high and normal
And im so confused cause if it runs good for abit why does it start dropping frames and then pretty much become unplayable
https://linustechtips.com/topic/979464-i-keep-dropping-frames-help/
1 minute ago, Mattk13 said:
specs
i3 3240
gt 1030 gddr5
6gb of ram
1 ssd 2 hard drives
Oem Dell Mobo
240watt psu
Have you checked your temperatures? Try using something like MSI afterburner for statistics to see what you CPU and GPU usage and temperatures are.
PSU tier list // Motherboard tier list // Community Standards
My System:
AMD Ryzen 5 3600, Gigabyte RTX 3060TI Gaming OC ProFractal Design Meshify C TG, 2x8GB G.Skill Ripjaws V 3200MHz, MSI B450 Gaming Plus MaxSamsung 850 EVO 512GB, 2TB WD BlueCorsair RM850x, LG 27GL83A-B
my i3 usally at 40 normaly then when gta starts going ive seen it get up to 60
On 10/5/2018 at 4:37 AM, Shimejii said:
Your vram or computer ram is probably getting filled and after that it throttles hard.
its not the vram cause ive seen people play at 70 at the settings i use and its fine so its the processor or the ram
i would bet it is the 6 gigs of ram, or the cpu struggling after a little bit.
And your GPU? And what about the usage of your CPU and GPU? If one of them is at 100% while the other is sitting on it's arse than you can figure out which of them is slowing you down.
My System:
the processor struggling? how im confused still XD
my gpu is usally 45 50 with gaming
What monitoring software are you using?
My System:
Speccy
Okay Yeah I can't really help you. If you want people to give you a more useful answer then I'd really suggest you install MSI Afterburner and check at least the following things:
- CPU usage (all cores)
- CPU temps
- GPU core usage
- GPU memory usage
- GPU temps
- Memory Usage
It does sound like a buffer filling up, this should at least give you a good idea of which component it is that is causing the slow down.
My System:
It's the CPU and GPU, but probably the CPU more so tbh, at least in GTA V, assuming you set your settings well
The title says it all. The i3 is crap, especially a 3rd gen one. Low clocks, low ipc from an old generation, ddr3 instead of ddr4, a low end platform like that is bound to perform poorly
Primary PC:
PSU tier list
How many watts do I need?
On 10/9/2018 at 11:31 PM, Arika S said:
lower your settings on GTA, your specs are not that great.
At minium its at 30 fps 20 and yet people can play the game at 60 with the settings i use figure that out its the Cpu
Not the gpu at all its gets the same performance through all the settings very high to Normal its get 20 -30 fps and it drops and drops over time its my cpu not my gpu at all
On 10/9/2018 at 11:26 PM, Shimejii said:
You have extreemly low end specs, its not going to run well at all to be fair
Not *Extremely Low end * at all look up my gpu in games you will be surprised
Well, I'm saying that it is also fairly low spec and would hold you back, provided you upgrade the CPU or find a solution to this problem that allows the bottleneck to shift to your GPU.
the GT 1030 is the lowest end GPU for the pascal lineup, there are also two variants of it, the GDDR5 and the DDR4 variants, both are not great performers, the 2nd being HORRID. The issues above could be the CPU is not able to keep up being a dual core with the game, running out of system meemory, or running against bare minimum game requirements
Just cause its the lowest end doesn't mean its bad
Same as gtx 750 Ti
Bottom line is that the hardware is weaksauce. Now what's really holding you back is the i3. Have you used task manager to see what usage is at?
Primary PC:
PSU tier list
Same as gtx 750 Ti
That's sufficient but about the lowest I'd recommend for that game.  It'll get you a solid 1080p60 experience with decent graphics, so I wouldn't call it "extremely low end" at all.  It's not a bad experience, but it's near the bottom end of what I'd recommend.
Also, -threads merged and moved-
Playing gta takes it to 99 to 100%
That right there is the problem. Stuttering caused by insufficient CPU power. 100% load means the little guy is trying his best, it's just not enough
Primary PC:
PSU tier list
Well that's pretty clear.  Just out of curiosity though, what is GPU usage like?  I bet less than 100%
Okay  can you help me with this
Im thinking of getting something better would a GTX 960 a core i7 2600 or a i7 3770 be a good choice with 16gb of ram
2 minutes ago, Arika S said:
so you're i3 is the bottleneck, you need a new processor
I kinda figured that its a 6year old dual core CPU
50 60
On your platform I think you could upgrade to a 3770, which I would recommend and would help, provided it's fairly cheap.  If you can't find one for cheap, don't bother, there's other options.
50 60
Alright well yup this is clear as day.  100% confident it's a CPU bottleneck.
Huh, that's weird. I was typing a reply on the thread before the merge and I was able to post it (which then took me to this thread), but it seems to have vanished in to the ether...
Anyway,
Now that you've established that your system is not fit for the purpose you are intending to use it for, are you looking to upgrade or replace it? If you're willing to spend some money on it, we can help you pick some upgrades or help come up with a replacement system to suit your budget. Just let us know what your budget would be and what you hope to achieve from the system (ie. playing GTA V at 1080p 60fps)
