Posted December 10, 2017 The centerpeice of this build is this motherboard, the x99 OC Formula (beastly eatx board)so the theme is gold and black, check The gpu will be a asus strix 980 ti with a full cover bitspower waterblock Now for the watercooling! What I have: SE 240 PE 360 D5 w/pumptop 10 black bitspower 3/8" 5/8" fittings, 4 90 degree and 4 45 degree angles acrylic, spray paint and power tools D5 5.25" pump/res DDC 5.25" pump/res I am considering: heatkiller glass res, maybe with d5 integration 400mm phobya radiator (if I get an h500p) hardline fitings/tubing primochill Vue (if there's a gold option?) full cover monoblock from bitspower X99 CPU block - either a gold bitspower EF or an x99 supremacy evo Now what case should I cram this into? Heavily modified H500p (mesh front and cut to fit a 400mm rad) Dark base 700 FD R5 if it has TG, maybe a meshify R? maybe a scratch build, Im quite handy so it is an option. something else? Name in the comments what you recommend added air 740 lian li 550x Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Maybe an Air 540 Case? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 that motherboard... I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 5 minutes ago, Damascus said: The centerpeice of this build is this motherboard, the x99 OC Formula (beastly eatx board)so the theme is gold and black, check The gpu will be a asus strix 980 ti with a full cover bitspower waterblock Now for the watercooling! What I have: SE 240 PE 360 D5 w/pumptop 10 black bitspower 3/8" 5/8" fittings, 4 90 degree and 4 45 degree angles acrylic, spray paint and power tools D5 5.25" pump/res DDC 5.25" pump/res I am considering: heatkiller glass res, maybe with d5 integration 400mm phobya radiator (if I get an h500p) hardline fitings/tubing primochill Vue (if there's a gold option?) full cover monoblock from bitspower X99 CPU block - either a gold bitspower EF or an x99 supremacy evo Now what case should I cram this into? Heavily modified H500p (mesh front and cut to fit a 400mm rad) Dark base 700 FD R5 if it has TG, maybe a meshify R? maybe a scratch build, Im quite handy so it is an option. something else? Name in the comments what you recommend This is a good primo hill vue yellow/gold https://www.primochill.com/collections/vue-unique-visual/products/primochill-vue-pre-mix-32oz-yellow Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author 2 minutes ago, e46 said: Maybe an Air 540 Case? Thanks for the reminder, I love its brother the air 740. added to the list Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author 3 minutes ago, Bananasplit_00 said: that motherboard... I know, right? I only paid 110 used for it too, that's less than what my garbage x370 cost Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 well, i stuffed about that amount of cooling into Northern Bee, and thats in a Define C, GPU is tight though so id probably go for a Define S I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Just now, Damascus said: I know, right? I only paid 110 used for it too, that's less than what my garbage x370 cost end my pain right here and now because the Z97 board goes for twice that at a minimum... I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author 2 minutes ago, Bananasplit_00 said: end my pain right here and now because the Z97 board goes for twice that at a minimum... My two RAM stick look so lonely Maybe when ram prices go down I'll invest in a second kit Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 One of my favourite cases is the corsair obsidian 900D http://www.corsair.com/en-gb/obsidian-series-900d-super-tower-case a bit costly but it looks really nice Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author Now to spam tag some peeps with nice wc builds @For Science! @done12many2 @NavyChief Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author Just now, Kitayuan said: One of my favourite cases is the corsair obsidian 900D http://www.corsair.com/en-gb/obsidian-series-900d-super-tower-case a bit costly but it looks really nice It's a bit big and I have some concerns in regards to build quality Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 1 minute ago, Damascus said: It's a bit big and I have some concerns in regards to build quality I think build quality is good, but there's no debate on its size Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Just now, Damascus said: My two RAM stick look so lonely Maybe when ram prices go down I'll invest in a second kit i snatched up 4x4GB of 2133MHz DDR3 for €55 with shipping just today, but not for that reason mainly 2 minutes ago, Damascus said: Now to spam tag some peeps with nice wc builds @For Science! @done12many2 @NavyChief y i no in dat list /s I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 10 minutes ago, Damascus said: It's a bit big and I have some concerns in regards to build quality 8 minutes ago, Kitayuan said: I think build quality is good, but there's no debate on its size I think the build quality of the 900D is indeed rather questionable. The steel bends quite easily and things like the enforced 5.25" bays annoyed me when I built mine. I also don't think for a simple build its justified (too big, as Damascus already said). H500P is you fix the airflow situation or FD gets my vote. Depends on the looks you're after (I personally prefer the FD case) Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author 3 minutes ago, For Science! said: I think the build quality of the 900D is indeed rather questionable. The steel bends quite easily and things like the enforced 5.25" bays annoyed me when I built mine. I also don't think for a simple build its justified (too big, as Damascus already said). H500P is you fix the airflow situation or FD gets my vote. Depends on the looks you're after (I personally prefer the FD case) Biggest issue with the Define R5 is that there just isn't a meshify/TG version out. I'm hoping for one but if it doesn't exist I can't buy it Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Just now, Damascus said: Biggest issue with the Define R5 is that there just isn't a meshify/TG version out. I'm hoping for one but if it doesn't exist I can't buy it Or go for the Meshify C, it'll mean you're limited to slim rads, but it'll be good enough for a single 980Ti I think Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author Just now, For Science! said: Or go for the Meshify C, it'll mean you're limited to slim rads, but it'll be good enough for a single 980Ti I think I could fit the radiators in there, bigger issue is the mobo. It's eatx and that kinda wrecks the meshify Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 25 minutes ago, Damascus said: Now to spam tag some peeps with nice wc builds @For Science! @done12many2 @NavyChief Buddy, I think you already know that I am a Caselabs junky. They are expensive as all hell, but it will be the last case you buy for a really long time. Even when new tech is released, Caselabs updates the removable parts such as rad, HDD, and misc water cooling mounts along with I/O ports to accommodate the new stuff like changes in USB standards. Tons of room for activities and specifically designed for full custom loops. You may spend a lot up front, but like I said, you won't be buying another for a very long time. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 2 minutes ago, Damascus said: I could fit the radiators in there, bigger issue is the mobo. It's eatx and that kinda wrecks the meshify With the PE360 the rad + fan will likely collide in with a full length graphics card. But yes, the E-ATX is a larger problem...The Air740 is a good case too, there is ample space for the setup. Although I find there is too much space in the back wasted. Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author Just now, done12many2 said: Buddy, I think you already know that I am a Caselabs junky. Sooomedaaayy, over the rainbow! When I make more than minimum wage I'll probably invest in a caselabs, or mill something comparable for myself. For now I think I'll need to cap myself at $200 TBH I expected this response, what do you think of using a modified h500p for 400mm in the front and 360 up above? Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 4 minutes ago, For Science! said: Or go for the Meshify C, it'll mean you're limited to slim rads, but it'll be good enough for a single 980Ti I think got a 45mm rad in the front, only limited to a slim rad up top, unless you have a longer than 270mm long GPU 3 minutes ago, Damascus said: I could fit the radiators in there, bigger issue is the mobo. It's eatx and that kinda wrecks the meshify i think that motherboard would fit that, but yah it would be really tight I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Author 1 minute ago, Bananasplit_00 said: got a 45mm rad in the front, only limited to a slim rad up top, unless you have a longer than 270mm long GPU 8 minutes ago, Damascus said: 305mm Want to custom loop? Ask me more if you are curious Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 3 minutes ago, Bananasplit_00 said: i think that motherboard would fit that, but yah it would be really tight Nah EATX wouldnt work in the Define C series, unless you want to hammer out the cable management area. Bitwit's build on the boat is a good referenfce. Recent builds: Meshify C (Zero Tolerance!) & View 37 (Breathable Quad 2080Ti + 2990WX) Best documented PC coolants Older Builds Spoiler Full-custom loop builds: Meshify C (Full custom loop SLI), Ncase M1(8700K + 1080Ti Full custom loop) Obsidian 900D (1950X + Quad 1080Ti) & Fractal Define C (1080 in SLI) Air-cooled builds Air 740D (1920X + Quad 980Ti) & Fractal Define C (Version Air!) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted December 10, 2017 Just now, Damascus said: 305mm well thats GG Define C frame out of the question basically, like i said the Define S would be a good pick IMO, seeing as its mainly just a thiccer Define C with more room for watercooling, sadly has no PSU shroud though but nor does the R5 I spent $2500 on building my PC and all i do with it is play no games atm & watch anime at 1080p(finally) watch YT and write essays... nothing, it just sits there collecting dust... Builds: The Toaster Project! Northern Bee! The original LAN PC build log! (Old, dead and replaced by The Toaster Project & 5.0) Spoiler "Here is some advice that might have gotten lost somewhere along the way in your life. #1. Treat others as you would like to be treated. #2. It's best to keep your mouth shut; and appear to be stupid, rather than open it and remove all doubt. #3. There is nothing "wrong" with being wrong. Learning from a mistake can be more valuable than not making one in the first place. Follow these simple rules in life, and I promise you, things magically get easier. " - MageTank 31-10-2016 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
