What is best AIR COOLER for i7-8700K
Solved by PopsiclesInMyCellar,
After extensive research, it turns out the Noctua NH-D15 is king (if it will fit!). I observed dozens of tests, videos, and reviews. This is the one I've gone with. It's even quieter than the be quiet! Dark Rock Pro 3! Can you believe it?!
I also may order some of their Chromax replacements to make it black in the future.
Featured Topics
joshfrog ·
Posted in Mobile Gaming0 -
1
f23948 ·
Aleph256 ·
Posted in Storage Devices0 -
15
Bonznumber1 ·
Posted in Windows0
