Should I wait for ZEN 2
Just now, Zic05 said:.
You're getting a couple of stuff wrong though, to begin with a great number of games barely even fully utilizes 4 cores today, software side it is a lot, but like A LOT more difficult than most people think to parallelize the work load through coding software side, so you can be sure we are nowhere that near of games fully using 6 cores (not even the case as system uses its share of resources too).
So having that in mind, even on games that can use 4 cores or more to some extend, the most important thing will always be IPC, the single core performance, the fastest possible cores and Zen+ will at best expectation even up with Skylake IPC, meaning that you'll be doing nothing but a sidegrade on best case scenario as the single core speed will be somewhat the same.
If you want an actual noticeable upgrade without wasting money do what I told you so, wait for Intel's Ice Lake line up, it will be first CPU gen to feature 10nm lithography which means faster cores.
