Need help. Is my gpu dying?
Solved by emosun,
43 minutes ago, Suomikoira12 said:I'm spamming my windows key in this video to have those artifacts show up.
no the gpu is probably fine. it probably has more to do with a minor software inconsistency with your specific combination of hardware which results in........ an overly specific glitch that can only be seen by spamming the windows key.
something small like a driver / bios / windows update is either to blame or is the solution for it.
your gpu would need to be freaking out a lot more than that in regular usage to actually have a hardware fault.
