Best cpu fan curve software
MancorJ
Go to solution Solved by Billy_Mays,
NZXT Cam will do that
Is there any cpu fan control program that can is as simple as adjusting the fan curve for like a graphics card on like msi after?urner?
i hate speedfan
thanks
Im mostly on discord now and you can find me on my profile
My Build: Xeon 2630L V, RX 560 2gb, 8gb ddr4 1866, EVGA 450BV
My Laptop #1: i3-5020U, 8gb of DDR3, Intel HD 5500
i hate speedfan
thanks
Just use the BIOS to set the fan curve.. very easy, dependant upon bios of course, but usually very easy. What board do you have?
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
I second this.
Unless the software can persistently set the fan curve somehow, use BIOS to keep it. Otherwise you have to launch the app to have the fan curve and I find that annoying.
<?lockquote class="ipsQuote" data-ipsquote="" data-ipsquote-contentapp="forums" data-ipsquote-contentclass="forums_Topic" data-ipsquote-contentcommentid="10240731" data-ipsquote-contentid="816573" data-ipsquote-contenttype="forums" data-ipsquote-timestamp="1501709375" data-ipsquote-userid="271594" data-ipsquote-username="paddy-stone">
5 minutes ago, paddy-stone said:
Just use the ?IOS to set the fan curve.. very easy, dependant upon ?ios of course, ?ut usually very easy. What ?oard do you have?
<?lockquote class="ipsQuote" data-ipsquote="" data-ipsquote-contentapp="forums" data-ipsquote-contentclass="forums_Topic" data-ipsquote-contentcommentid="10240734" data-ipsquote-contentid="816573" data-ipsquote-contenttype="forums" data-ipsquote-timestamp="1501709465" data-ipsquote-userid="359972" data-ipsquote-username="M.Yurizaki">
4 minutes ago, M.Yurizaki said:
I second this.
Unless the software can persistently set the fan curve somehow, use ?IOS to keep it. Otherwise you have to launch the app to have the fan curve and I find that annoying.
The ?ios fan support is gar?age, there is only "smart fan" where if the cpu is a?ove 50 degrees it turns into a jet engine.  naturally i would tho
Edit: its an old giga?yte mother?oard
2 minutes ago, M.Yurizaki said:
I second this.
Agree, IMO there's nothing worse than having to launch processes at boot, just to set the fan curve is even worse. It also means that up 'til that point your fans could be going nuts.
I don't like a constant ramping up/down of fans personally, so I have mine set at 40% mimum, then when/if it reaches say 50c, then they ramp up to 50/60% and so on.... that way if I'm just doing something light on my system it should only be about 40% ... nice and quiet for just web browsing etc.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
Just now, M.Yurizaki said:
Is it just me or are @MancorJ's posts ?utchered? I'm seeing weird ?s and HTML code.
its my friends computer and in chrome every ? is a ? emoji
Not unless OP gets Grid+. Otherwise its just for monitoring.
Gigabyte isn't very good with fan controls. Period. Only their newest boards are starting to get in same level that Asus had few years ago. You are stuck with Speedfan. Good thing is that you only need to set it up once and then you can just forget it.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
I can adjust my GPU fan speed with no NZXT parts at all
We are talking about CPU fan, though. And probably case fans too. Unlike GPU fan (which has ton of RivaTuner clones), those use mobo chips. For which Speedfan has for long been only alternative. I could check what you actually can do with CAM. Last time I used it, was when it was on Beta.
Ok I dont have any PWM fan headers on my mobo right now but I may get a cheap Z170 board
