Hi SFF question
i have a Lian li /dan H20 itx case
https://lian-li.com/product/a4h2o/
I still need to get a 240 aio (55mm. max total thickness with fans)(water block max cleareance is 55 mm)for a 7950x3d on a X670E-I motherboard
https://rog.asus.com/us/motherboards/rog-strix/rog-strix-x670e-i-gaming-wifi-model/
What 240mm aio  would you suggest ?
https://linustechtips.com/topic/1570068-itx-aio-55mm/
Look at completed builds and see what they're using.
https://pcpartpicker.com/builds/by_part/jT7G3C
Side note, i'm amazed someone actually bought that motherboard.
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
https://linustechtips.com/topic/1570068-itx-aio-55mm/#findComment-16406992
Yeah same , ive always ended up needing fuck loads of usb and i was going to go the board down but for a extra 100 for 3 more usb i figured why not .
https://linustechtips.com/topic/1570068-itx-aio-55mm/#findComment-16406995
Cheer's let me pick a cooler pretty quick , going with  a "EKWB Nucleus CR240 Dark"
https://linustechtips.com/topic/1570068-itx-aio-55mm/#findComment-16406999
Great product, highly unethical company.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1570068-itx-aio-55mm/#findComment-16407394
4 hours ago, dead man jack said:
indeed but I've always wanted to try ek since I saw a custom loop , ended up with a h100i while i was at the shop .
It's your choice, just making sure you're aware. Certainly not the only unethical company out there. It's probably harder to find an ethical one.
https://linustechtips.com/topic/1570068-itx-aio-55mm/#findComment-16408386
