Sapphire RX570 ITX vs EVGA 1060 SC 6GB
mapegl
Which if the two would you get and why? The gtx 1060 could also be replaced by any other itx variant of the 1060, however I feel like the EVGA SC is the best option.
It needs to fit in an Elite 110 from Cooler Master.
Edit: I am talking about the 6GB 1060. Also the 570 ITX us only available in 4GB. Just for clarification.
PC: AMD Ryzen 5 3600 @4.2HGhz 1.25V || Noctua NH-U12S SE2 || 16GB (2×8GB) Aegis 3000Mhz CL16 @3200Mhz ||
|| Sapphire Pulse RX 6700 10G || MSI B450i Gaming PLUS MAX Wifi
  || Kingston NV1 2TB m.2 ||  Corsair SF600 || Intertech IM 1 |||
Peripherals: Sennheiser PC  360 G4ME || AOC CQ27G2U || Viewsonic PX701HD || Keychron V1 || Logitech G303 Shroud Edition||| Laptop: XPS 13 2in1 7390 || Steam Deck 256 GB (64GB Version) ||| Cameras: Fujifilm XH-1 || Fujifilm X100T
Elite 110 build log (update:05/15/2018)
1060 3gb or 1060 6gb?
Get the 1060 3G/6G over the 570, the 580 should be the same price as the 1060s tho
GTX 1060 6GB
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
GTX 1060, but the EVGA SC is really bad at VRM cooling
idk
RX 580/570 prices have jumped thx to Bitcoin mining craze is back
if not for the price
the RX 570 will be the good buy
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
I have an EVGA 1060 SC in the itx build I gave the gf and it works great as a 1080p card.
The 570 ITX actually costs around 190, while the 1060 costs around 260+. Big difference in price.
I guess bitcoin craze in Germany has yet to arrive. ;-)
the 570 is a bit slower than the GTX 1060 3GB but not by much
for that price yes if you are on a budget, the 570 is the no brainer
but for performance yet in a SFF then get the GTX 1060
Why not an RX 580/480 then?
1060 3GB > RX 570/470 > 1060 6GB = 580/480 4GB > 580/480 8GB
QUOTE/TAG ME WHEN REPLYING
Spend As Much Time Writing Your Question As You Want Me To Spend Responding To It.
If I'm wrong, please point it out. I'm always learning & I won't bite.
Desktop:
Delidded Core i7 4770K - GTX 1070 ROG Strix - 16GB DDR3 - Lots of RGB lights I never change
Laptop:
HP Spectre X360 - i7 8560U - MX150 - 2TB SSD - 16GB DDR4
As I stated in my original post: the case has serious limitations.  There are no short RX480 or RX580 cards....
if you need small, then 1060 6GB is your card. small coolers usually have bad thermals, and Pascal is more efficient than Polaris.
Desktop:
Laptop:
the RX 570 is very slightly slower than the 1060 3gb(like around 2% or so), its no match for the 6gb gtx 1060.
Sucks. I was looking at the rx 570 itx feom sapphire. It is really cheap and apparently decently cooled. I guess I will hold out a bit longer for something that makes sense. I don't want to downgrade too much from my current 8gb RX480.
580>480>1060 6gb>570>470>1060 3gb
13700k, 3070, 32GB@3200
you're getting a downgrade from going with a 480 to an RX 570. if you wanna upgrade a gtx 1070/980ti/r9 fury x would be more appropriate.
