So right now I've got a 360mm rad and a 240mm rad for both GPU and CPU. I have the ability (spare parts) to separate the loop and do one for a GPU and one for the CPU.
Would it it be more beneficial to run separate loop even though I'm only running a 360mm on the CPU and a 240 on the GPU. Or is it more beneficial to have them both in the same loop?
https://linustechtips.com/topic/767386-separate-loop-or-single-loop-question/
seperate loops are pointless, i won't go into the thermo-physics of it, but a single loop is better. many pros, no cons compared to separate loops.
We can't Benchmark like we used to, but we have our ways. One trick is to shove more GPUs in your computer. Like the time I needed to NV-Link, because I needed a higher HeavenBench score, so I did an SLI, which is what they called NV-Link back in the day. So, I decided to put two GPUs in my computer, which was the style at the time. Now, to add another GPU to your computer, costs a new PSU. Now in those days PSUs said OCZ on them, "Gimme 750W OCZs for an SLI" you'd say. Now where were we? Oh yeah, the important thing was that I had two GPUs in my rig, which was the style at the time! They didn't have RGB PSUs at the time, because of the war. The only thing you could get was those big green ones.
Unless your temps are really high I don't see why you would need to.
Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples:
Do this:
Quote
And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor!
Or this:
@DocSwag
Buy whatever product is best for you, not what product is "best" for the market.
Interested in computer architecture? Still in middle or high school? P.M. me!
I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that.
Compooters:
Desktop:
CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync)
Home Server:
CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter?
Laptop (I use it for school):
Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050
And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb
even then, you won't see a difference. if you are water cooled the only thing that can reduce your temps is more water capacity, more radiators, or better fans (up to the maximum dissipation point of the radiator metal.)
Two loops would increase water capacity while requiring two pumps, increasing water flow, both of which should decrease temps.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
not true, two loops is not the same as increasing water capacity, it's the water capacity of the entire single loop that must increase. additionally, increasing water slow will not decrease temperatures.
I really, don't want to go on a long rant about the thermal dynamics of it, please don't make me.
You're gonna need two reservoirs though, which should generally increase water capacity. Of course, it's not guaranteed to but it should.
As for water speed, actually yes it will. It's a similar concept to wind chill.
Also, I'm pretty sure you're not supposed to say thermal dynamics but thermodynamics :P
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
@DocSwag you didn't listen to what he said at 7:00+ did you?
he's basically cutting the flow to almost nothing. listen to what he said at 8:45ish. YOU WONT SEE MUCH OF A DIFFERENCE BETWEEN MAX AND MIN.
that's because once all of the water is heated in the loop the best you can do is dissipate it better via more radiators, or adding more water to absorb more heat. take some lessons on heat capacity and specific heat.
it's not like windchill, it's like blood. blood at any point in your body is the same temperature. even if you have high or low blood pressure.
after the loop has ran for a short while the entire loop with have a very small delta at any given point in the loop, there becomes no such thing as pushing GPU heat into a CPU. thus it is unnecessary to have two loops in one system.  Jay has another video explaining this, but it's 30+ minutes long and from like 2012.
a system can benefit from two pumps in series, in terms of noise and redundancy, but once you get your liquid to full heat capacity, your flow rate is nearly negligible, as long as it's flowing properly. the flow vs dissipation curve looks like a root function graph, diminishing returns until no return.
@suits there is no need to make two loops, you will not pump heat into one component to another, so don't worry. two reservoirs or two pumps can be beneficial in series, but not needed.
I'm too lazy to watch it again :P
Also, there is a difference, it's just not very big, due to water being a pretty good thermal conductor, but there is some. There's a reason why he got lower temps.
I never said it was a big difference, I just said that there IS a difference xD
2 loops isn't and won't ever really be worth it for thermal reasons, only for aesthetics.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
I would have to agree with VioDuskar in this case. More radiators in a single loop will be a better choice.
under most situations your cpus and gpus will not be under full load at the same time so having a 240+360 rad cooling the single component under load will allow for better heat dissipation. This also holds true even if both components are under full load.
Although the posters above mentioned total water capacity improving cooling performance, I would say this is slightly inaccurate. having a larger body of water would mean it would take longer for the system water to reach equilibrium (and thus stay closer to ambient temperature for longer) however the final cooling capacity is dictated by the radiator area and fan speed and so the system would ultimately reach the same temperature over time even if you had a bigger reservoir.
so in summary single loop is better. the one advantage of a dual loop is if you know you want to swap out gpus or cpus often and so you can drain one part of the loop without affecting the other.
Do which ever. Wont matter with such few components and radiators. If you have the room and want to do that much work go right ahead.
I have a single pump for 2 rads and 8 blocks.
I also ran 5 rads for 3 blocks and 1 pump.
I will only do a dual loop for a large case like my x9, just to take up more space and to swap out cards easier.
I'm not disagreeing with that xD. I'm just saying that having two loops DOES give a slight performance advantage, it's just EXTREMELY slight.
Do this:
Quote
Or this:
@DocSwag
Compooters:
Desktop:
Home Server:
The only benefit of dual loops is easier troubleshooting. Since your GPU(s) are on a separate loop than your CPU, it will be easier to find clogged blocks, especially if you only have 1 GPU.
Otherwise, it's all about aesthetics.
Come Bloody Angel
Break off your chains
And look what I've found in the dirt.
Pale battered body
Seems she was struggling
Something is wrong with this world.
Fierce Bloody Angel
The blood is on your hands
Why did you come to this world?
Everybody turns to dust.
The blood is on your hands.
The blood is on your hands!
Pyo.
I've played around with dual loops a couple times and imo it isn't worth it unless you're running 3x Titan X  and a 6950x or something like that.  What I found was that when gaming, my GPU loop with 2x gtx 980's would get too hot for my liking, even with a 280mm and a 140mm radiator.  Meanwhile, my cpu loop was ice cold with a 240mm radiator and by separating the loops I was removing the ability to use all the radiators capabilities all the time.  Unless you are perfectly balancing your radiator space then you will likely get less effective cooling by going with 2 separate loops because one portion of the loop (likely the cpu loop) won't be using the radiator to it's full extent, while the other is operating at it's thermal limit.  Especially true while gaming since most games won't utilize most cpu's to 100% so they aren't even dumping that much heat.   The GPU will likely run at/close to 100% the entire time dumping heat into the loop.
unless you've got the space to completely overkill both loops with radiators, I would just stick with a single loop.
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
Like other individuals have stated.
Pointless in a every day computer or gaming computer.  Even a folding/boinc rig can get away with a proper single loop when built right (a good amount of radiators).
In the case of your components, it is a waste of money, time, and effort unless you going for looks.
To give you an idea, I fold and boinc (these two put greater loads than gaming) on two highly OCed 980Tis and previously a delid 4770K.  Highest temps I saw was 50C on the GPUs and 60-65C on the CPU at full loads on all of them.  This is with a 360 and 200 radiators in my loop.  You have an extra 40mm length radiator to me.  You will be fine.
2023 BOINC Pentathlon Event
F@H & BOINC Installation on Linux Guide
My CPU Army: 5800X, E5-2670V3, 1950X, 5960X J Batch, 10750H *lappy
My GPU Army:3080Ti, 960 FTW @ 1551MHz, RTX 2070 Max-Q *lappy
My Console Brigade: Gamecube, Wii, Wii U, Switch, PS2 Fatty, Xbox One S, Xbox One X
My Tablet Squad: iPad Air 5th Gen, Samsung Tab S, Nexus 7 (1st gen)
3D Printer Unit: Prusa MK3S, Prusa Mini, EPAX E10
VR Headset: Quest 2
Hardware lost to Kevdog's Law of Folding
OG Titan, 5960X, ThermalTake BlackWidow 850 Watt PSU
