Cooler Master 212x fans
coolmrschill
My pc theme is red and I was wondering if you could or if it would be a big deal to swap the standed black fans with some red ones
nope, should be all good. just make sure the fan is PMW so it can be controlled better. any standard 120mm fan should work. better bearing would make it quieter if you can find red one with a fluid bearing i would pick that one.  i also don't know your pc specs but, if it isn't overheating now it shouldn't with different fans.
I'm building my first PC with these these parts :). With a Cooler Master 212x could I overclock it a fair bit? What would you recommend under the same price range for maximum overclocking ability while still being very quiet?
i have the 6600k with that exact cooler running 4.8ghz @ 1.38v with the hottest core of arround 73c with constant non stop gaming. - So the answer is yes.
Thanks!
It depends a bit on ambient temperatures, but yeah
desktop
r5 3600,3450@0.9v (0.875v get) 4.2ghz@1.25v (1.212 get) | custom loop cpu&gpu 1260mm nexxos xt45 | MSI b450i gaming ac | crucial ballistix 2x8 3000c15->3733c15@1.39v(1.376v get) |Zotac 2060 amp | 256GB Samsung 950 pro nvme | 1TB Adata su800 | 4TB HGST drive | Silverstone SX500-LG
HTPC
HTPC i3 7300 | Gigabyte GA-B250M-DS3H | 16GB G Skill | Adata XPG SX8000 128GB M.2 | Many HDDs | Rosewill FBM-01 | Corsair CXM 450W
1 minute ago, coolmrschill said:
Thanks!
Yeah, dont expect those exact #'s for your cpu. It could be "worse" or much better.
Here is my build. Currently have the Cooler Master 212x looking for a quieter model with the same performance.
If you want a quieter heatsink, just replace the fan on it, rather than the entire heatsink itself.
Be Quiet or Noctua are good options, depending on budget.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
Deepcool, be quiet!, and Noctua make much better fans compared to the 212's stock fan.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
If all you're going for a quieter system, then just get a be Quiet Silent Wings 3 fan and you're good to go.
The Silent Wings 3 is probably the quietest fan on the market.
1 minute ago, TheRandomness said:
A Noctua NH-D15 with no fans. No fans = no noise c:
Eh...
I'd go with a corsair H60 and a custom fan curve that doesnt turn the fan on until 50C. A bit more... reliable, in case the fans are needed.
The fan could still be replaces of course
Solitaire.
Then I would rather take a cooler that is designed to run passive like the Thermaltake Le Grand Macho...
1 minute ago, Stardar1 said:
Eh...
The D15 outperforms the H60 :P
Well, whichever's cheaper :P
USEFUL LINKS:
PSU Tier List F@H stats
I hope it does. It's more expensive. o.O
right, but simply taking the fans off could have consequences if the CPU does end up requiring them.
in either event, the simplest solution is just to get 2 nice Noctua fans for the heatsink @coolmrschillalready has.
Solitaire.
Corsair Air Series AF120 or the Noctua NF-F12 PWM? Which one is better for the price?
You don't need waterproofing on your fans. AF120. If you want quieter, find something else.
Put 2fan on your cooler (high static pressure recommended) and you're good to go. watch overclocking guide here:
For my first build I think I'm going to get a Cooler Master 212x but I don't like the fans so I'm going to replace them with the Cosair SP120's. But I was thinking would it be cheaper to just by the heatsink without fans?
Just get the hyper 212 man, also why bother replacing the fans? also 2 fans really isn't going to make a difference
Also I'd totally go with fractical design Venturi 140mm fans as they'll be a bit bigger/quieter and you can make them fit where 120mm fans fit
Or just buy a Noctua heatsink
The 212 is pretty bad if you are just planning on replacing the fans. I would recommend getting something like the H7, as it looks nicer and performs about the same maybe a little better
What Noctua heatsink would you recommend?
What's your build and what are you trying to cool? also what's your case and budget?
