GPU Enclosure Options for RGB LED Strip Integration - Emmanuel Katto Uganda
Hey everyone, I am Emmanuel Katto and I'm in the process of building a new gaming PC. I'm looking for some recommendations on GPU enclosure options that support RGB LED strip integration. I've got my heart set on a custom liquid cooling loop and I want to make sure the GPU enclosure I choose has a spot for installing an RGB LED strip.
I've narrowed it down to a few options, but I'm having trouble finding specific information on each of their compatibility with RGB LED strips. Here are the enclosures I'm considering:
  • Lian Li O11 Dynamic
  • Phanteks Eclipse P400A
  • In Win 805
  • Thermaltake Core P1
Could anyone provide some insight into which of these enclosures have a designated spot for installing an RGB LED strip? Are there any specific models or versions that are more compatible with RGB LED strips than others? Please let me know.
Thanks in advance!
Emmanuel Katto
Why do you need a GPU enclosure for a gaming PC? Are you looking to make your gaming experience significantly worse for the purpose of looks?
  • In Win 805
Thanks in advance!
Emmanuel Katto
I reckon none of those cases are DIRECTLY compatible with rgb led strips but that doesnt mean you cant fit it in somewhere, just takes a little DIY, so just choose the case yo like the best that looks like it would suit your query
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem, max OC]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
1 minute ago, Levent said:
Why do you need a GPU enclosure for a gaming PC? Are you looking to make your gaming experience worse for the purpose of looks?
I think he means PC case just?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
