Cooler Master 212x fans
coolmrschill
4 minutes ago, coolmrschill said:
This is my build. My Theme is red. Trying to cool a 6600k for heavy overclocking. no more than $110CAD. My case is the Enthoo Evolv Black/Red Mini-ITX.
So you haven't bought the build yet?
No nothing, should note this is my first build but i've pc gamed for years on an MSI GT70
making a list atm, will be done in a bit
but the i7 6700 non K is a better choice than an i5 6600K at the same price, 4 cores at 4.5ghz avg OC is so not worth losing getting 8 threads with a 4gbs turbo, the price should be similair in the end with a more budget motherboard
And is $400 CAD the normal price of the 1060 6GB card?
because an RX 470 is a way better value at $260 CAD here
https://ca.pcpartpicker.com/product/RvjWGX/powercolor-radeon-rx-470-4gb-red-devil-video-card-axrx-470-4gbd5-3dhoc
Yes the MSI GTX 1060 6gb Gaming X is normaly 412 but onsale currenlty. I think I going to stay with my 6600k because make the 6700 the same price I will have to get a very cheap mobo
not really, the motherboard will be fine this ones comes with wifi, and it's easily worth all the extra multi-threaded performance with the i7, ITX changes it a bit though, it's only $100 CAD difference, that basically comes from changing the GPU
essentially with the i7 you shouldn't have any real reason to replace it anytime soon, as with the i5 you're limited to 4 threads even if they are a bit faster per thread
and ya I'd go RX 470 at $150 difference, the extra performance of the 1060 isn't going to be worth it
plus you can get this display which would be a bit better for gaming, it's a 75Hz TN free-sync display
it would also be a fair amount less if you went micro ATX, also upgraded the PSU
and you really won't need the extra fans, won't help cooling too much in an ITX case since it's already all packed close
AMD SSD for the luls, not sure if the kingston SSD has the same issue as the V300 series
PCPartPicker part list: http://ca.pcpartpicker.com/list/pj7xgL
Price breakdown by merchant: http://ca.pcpartpicker.com/list/pj7xgL/by_merchant/
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($397.75 @ Vuugo)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($36.75 @ Vuugo)
Motherboard: MSI B150I GAMING PRO AC Mini ITX LGA1151 Motherboard  ($144.99 @ NCIX)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($89.99 @ Newegg Canada)
Storage: AMD Radeon R3 240GB 2.5" Solid State Drive  ($84.85 @ DirectCanada)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($59.99 @ Newegg Canada)
Video Card: PowerColor Radeon RX 470 4GB Red Devil Video Card  ($259.99 @ Newegg Canada)
Case: Phanteks Enthoo EVOLV ITX Mini ITX Tower Case  ($89.99 @ NCIX)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($94.98 @ NCIX)
Monitor: AOC G2260VWQ6 21.5" 75Hz Monitor  ($181.42 @ shopRBC)
Total: $1440.70
Generated by PCPartPicker 2016-10-02 21:15 EDT-0400
As far as your CPU cooler goes, just stick to the stock fans man
19 hours ago, Senzelian said:
Then I would rather take a cooler that is designed to run passive like the Thermaltake Le Grand Macho...
It's designed to be used semi-passively with case fans.
19 hours ago, coolmrschill said:
Corsair Air Series AF120 or the Noctua NF-F12 PWM? Which one is better for the price?
Hard to tell if you don't mention the price. Also, a NF-S12A would be better than a NF-F12. It's probably your best option for the quietest well performing fan. http://ca.pcpartpicker.com/product/BgvRsY/noctua-case-fan-nfs12apwm
A cheaper option could be a Dual-X: http://ca.pcpartpicker.com/product/r4ckcf/cougar-case-fan-cfd12hbr
or Hyperborea: http://ca.pcpartpicker.com/product/qKvRsY/rosewill-case-fan-rocf11004
If you want a good red fan, you can get an AF120 QE or Magma Advance:
http://ca.pcpartpicker.com/product/PZNp99/corsair-case-fan-co9050001ww
http://ca.pcpartpicker.com/product/kFBv6h/enermax-case-fan-ucmaa12a
19 hours ago, OsuMasterz said:
You don't need waterproofing on your fans. AF120. If you want quieter, find something else.
? Neither fans are waterproof.
19 hours ago, Stardar1 said:
right, but simply taking the fans off could have consequences if the CPU does end up requiring them.
in either event, the simplest solution is just to get 2 nice Noctua fans for the heatsink @coolmrschillalready has.
There's no need for 2 fans. 1 is plenty.
20 hours ago, SlyTroopah said:
Yeah, dont expect those exact #'s for your cpu. It could be "worse" or much better.
The oc and temps seem very good. It's extremely unlikely to get much better with a 212 Evo.
