Do switches actually need a fan?
Solved by dalekphalm,
2 minutes ago, leadeater said:100% that is a 2U switch. Hard part will be finding a fan both small enough to go in it that is also quiet, since it will be a 40mm or 60mm fan.
Indeed, I'd be surprised if it was 80mm or larger. Noctua makes a really nice 40mm fan that is pretty thin. I replaced the PSU fan for my SE3016 SAS Expander with one (Goddamn jet engine, before the replacement).
Featured Topics
Splatacake ·
Posted in Peripherals1 -
2
6
MiszS ·
Posted in Operating Systems0 -
vortexx21 ·
7
Elite Knight ·
Posted in CPUs, Motherboards, and Memory13 -
Juan Sulthon ·
Posted in Troubleshooting0
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
