RaspAP/OpenWRT alternative with multi-VLAN WiFi networks?
RaspAP currently doesn't support it, and OpenWRT seems to only support it on wired level only.
Is there a software for Raspberry Pi (with WebGUI) that supports that?
To clarify, I just need them to act as an access point that supports multiple SSIDs that can be tagged to specific VLANs.
I have OPNsense for DNS/DHCP/VLANs & managed L2 switches
Desktop
Y4M1-II: AMD Ryzen 9-5900X | Asrock RX 6900XT Phantom Gaming D | Gigabyte RTX 4060 low profile | 64GB G.Skill Ripjaws V | 2TB Samsung 980 Pro + 4TB 870 EVO + 4TB SanDisk Ultra 3D + 8TB WD Black + 4TB WD Black HDD | Lian Li O11 Dynamic XL-X | Antec ST1000 1000W 80+ Titanium | MSI Optix MAG342CQR | BenQ EW3270U | Kubuntu
Mobile devices
Kuroneko: Lenovo ThinkPad X1 Yoga 4th (Intel i7-10510U | 16GB RAM | 1TB SSD)
By that you mean passing VLAN tags from WLAN clients? Never thought of that myself. You can do multiple SSIDs per VLAN though.
OpenWRT has a RPI image, doesnt that work for you?
https://firmware-selector.openwrt.org/
Yup! that's what I meant.
Weird.  Unless I was looking at the wrong spot, I didn't see that
Desktop
Mobile devices
You have to configure VLANs in devices then create interfaces using the device you created. Then you simply connect an AP to the said interface. First half is the only part that is different than setting up a regular network with no vlans.
I know OpenWRT can be a dedicated router, but in this case, it won't be.  In my setup, the OpenWRT/Raspberry Pi will be just be an access point.
I have OPNsense for DHCP/DNS/VLAN, and layer 2 switch for tagging
Desktop
Mobile devices
This is the same. I just dont have managed switch and enough free ports on the AP, I just use one trunk for all my WLANs.
OpenWRT does no packet processing other than adding or removing VLAN tags.
Aah. Ok. I got confused when you said to plug the AP to the interface.  I was hoping for just 1 hardware that would do multiple SSIDs
I was hoping to be able to use my Pi for other things (i.e. AirPlay music player).
I also have a mini PC with 4c i5-6500T, and considered using a VM, but I think it may be too much for with a virtual interface.
I'm currently exploring all of my options, and would experiment when I get the time.
I just finished the wired component and testing things out before I put the family router in my network and convert it as an AP/switch.
Desktop
Mobile devices
I know UniFi network can do it. Not sure if that’s what you’re looking for though.
You can buy an AP that supports Multi SSID, I have a TP-LINK TL-WA1201 that supports up to 4 VLANs. Works for both 2.4Ghz and 5ghz..
CPU: AMD Ryzen 5 5600X | CPU Cooler: Stock AMD Cooler | Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) | RAM: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 CL16 | GPU: Nvidia GTX 1060 6GB Zotac Mini | Case: K280 Case | PSU: Cooler Master B600 Power supply | SSD: 1TB  | HDDs: 1x 250GB & 1x 1TB WD Blue | Monitors: 24" Acer S240HLBID + 24" Samsung  | OS: Win 10 Pro
Audio: Behringer Q802USB Xenyx 8 Input Mixer |  U-PHORIA UMC204HD | Behringer XM8500 Dynamic Cardioid Vocal Microphone | Sound Blaster Audigy Fx PCI-E card.
Home Lab:  Lenovo ThinkCenter M82 ESXi 6.7 | Lenovo M93 Tiny Exchange 2019 | TP-LINK TL-SG1024D 24-Port Gigabit | Cisco ASA 5506 firewall  | Cisco Catalyst 3750 Gigabit Switch | Cisco 2960C-LL | HP MicroServer G8 NAS | Custom built SCCM Server.
This can be done on OpenWRT as mentioned above.  Although I doubt a RPi makes a good Access Point.
On my Devices tab I have:
So I created Device br-lan.666 for the VLAN tags and a bridge called IoT.
On my Interfaces tab I created an unmanaged interface set to device IoT.
I then set the Network on the WiFi SSID to IoT.
So IoT is a bridge of VLAN 666 and the United Federation of Planets SSID.
Router:  Intel N100 (pfSense) WiFi6: Zyxel NWA210AX (1.7Gbit peak at 160Mhz)
WiFi5: Ubiquiti NanoHD OpenWRT (~500Mbit at 80Mhz) Switches: Netgear MS510TXUP, MS510TXPP, GS110EMX
ISPs: Zen Full Fibre 900 (~930Mbit down, 115Mbit up) + Three 5G (~800Mbit down, 115Mbit up)
Yea I gave it a spin, and I decided it's not worth it 😞
Bummer.
Yup, I decided to go for this route.  Just gonna save some money for one with WiFi 7
Desktop
Mobile devices
