Posted August 5, 2016 Why do desktop CPU's have heat spreaders? I work in the portable computer market and none of the processors in laptops etc have a heat spreaders, the thermal compound and cooling solution are mounted directly onto the CPU die. I'm sure there is a good reason, or they wouldn't bother. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2016 Im guessing the die is alot smaller and the heat spreader helps add surface area to help cool the chip Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2016 1 minute ago, Riley-NZL said: Why do desktop CPU's have heat spreaders? I work in the portable computer market and none of the processors in laptops etc have a heat spreaders, the thermal compound and cooling solution are mounted directly onto the CPU die. I'm sure there is a good reason, or they wouldn't bother. i could be wrong but maybe for aftermark coolers and such || CPU Intel Core i7‑4790K 4.9 Ghz || Motherboard MSI Z97S SLI Krait Edition || RAM corsair vengeance pro 4x8gb 2400mhz || GPU msi msi twin frozr gtx 1080 8g sli x2 || Case nzxt phantom 410 || Cooling corsair h100i || Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2016 Author 1 minute ago, tp95112 said: Im guessing the die is alot smaller and the heat spreader helps add surface area to help cool the chip Mobile CPU dies are generally somewhat smaller then Desktop dies. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2016 Probably cuts down on cracked dies from people that don't know what they're doing. Stuff: i7 7700k @ (dat nibba succ) | ASRock Z170M OC Formula | G.Skill TridentZ 3600 c16 | EKWB 1080 @ 2100 mhz | Acer X34 Predator | R4 | EVGA 1000 P2 | 1080mm Radiator Custom Loop | HD800 + Audio-GD NFB-11 | 850 Evo 1TB | 840 Pro 256GB | 3TB WD Blue | 2TB Barracuda Hwbot: http://hwbot.org/user/lays/ FireStrike 980 ti @ 1800 Mhz http://hwbot.org/submission/3183338 http://www.3dmark.com/3dm/11574089 Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2016 The die is much smaller than the heat spreader, look up what de-lidded CPUs look like. It also protects the CPU when you clamp a cooler onto it. ASU Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 5, 2016 2 minutes ago, Riley-NZL said: Why do desktop CPU's have heat spreaders? I work in the portable computer market and none of the processors in laptops etc have a heat spreaders, the thermal compound and cooling solution are mounted directly onto the CPU die. I'm sure there is a good reason, or they wouldn't bother. Commons sense would tell me that since the CPU is laying on pins and is not soldered would need more spread force (applied by the cooler) to not lose contact. Also the CPU socket and the ledge needs something to press down on and if it was just the substrate I bet that would bend or brake. CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Surface area. "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 5 minutes ago, intelCore said: Commons sense would tell me that since the CPU is laying on pins and is not soldered would need more spread force (applied by the cooler) to not lose contact. Also the CPU socket and the ledge needs something to press down on and if it was just the substrate I bet that would bend or brake. What about AMD CPUs? In both cases, the pins on the CPU/CPU socket bend from the pressure. You can use a CPU without a heatspreader just fine. But heatspreaders also add rigidity - if too much pressure is applied by the CPU cooler, it can actually crush a CPU die that's "exposed." "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 2 minutes ago, Godlygamer23 said: Surface area. Why no headspreader on graphics cards then? CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 2 minutes ago, Godlygamer23 said: What about AMD CPUs? You can use a CPU without a heatspreader just fine. But heatspreaders also add rigidity - if too much pressure is applied by the CPU cooler, it can actually crush a CPU die that's "exposed." AMD CPUs have yet to lay on pins as far as I know since intel CPUs used to not have a heatspreader when they still had their pins on the substrate aswell. CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Just now, intelCore said: Why no headspreader on graphics cards then? It turns out GPUs are actually easier to cool. "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Just now, Godlygamer23 said: It turns out GPUs are actually easier to cool. Huh how's that? CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 2 minutes ago, intelCore said: Why no headspreader on graphics cards then? Because adding aftermarket heatsinks to Graphics Cards is a lot less common than your regular CPU heatsink. Desktop: KiRaShi-Intel-2022 (i5-12600K, RTX2060) Mobile: OnePlus 5T | Koodo - 75GB Data + Data Rollover for $45/month Laptop: Dell XPS 15 9560 (the real 15" MacBook Pro that Apple didn't make) Tablet: iPad Mini 5 | Lenovo IdeaPad Duet 10.1 Camera: Canon M6 Mark II | Canon Rebel T1i (500D) | Canon SX280 | Panasonic TS20D Music: Spotify Premium (CIRCA '08) Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 (edited) 4 minutes ago, intelCore said: AMD CPUs have yet to lay on pins as far as I know since intel CPUs used to not have a heatspreader when they still had their pins on the substrate aswell. In both cases, the pins are bending from the retention pressure. There is no need to think about the loss of contact - the amount of pressure present in the mount is sufficient to hold down the CPUs. Edited August 6, 2016 by Godlygamer23 "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Just now, intelCore said: Huh how's that? Some oldie posts: https://linustechtips.com/main/topic/27337-gpu-vs-cpu-heat-output/?do=findComment&comment=347530 https://linustechtips.com/main/topic/27337-gpu-vs-cpu-heat-output/?do=findComment&comment=348279 "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Probably because CPU coolers have to be installed manually by clumsy human hands and too many people were dropping screwdrivers onto the die and breaking them or something. Laptops and GPUs come with cooling solutions installed. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 14 minutes ago, kirashi said: Because adding aftermarket heatsinks to Graphics Cards is a lot less common than your regular CPU heatsink. Waterblocks on graphics card have become a thing I think. 13 minutes ago, Godlygamer23 said: In both cases, the pins are bending from the retention pressure. There is no need to think about the loss of contact - the amount of pressure present in the mount is sufficient to hold down the CPUs. And that is exactly my point. While the whole "pins on the CPU going into the socket" mounting variant does not rely on pressure from above LGA sockets do. Whether it is from the retention bracket of the socket itself or the cooler doesn't matter. It needs force to push it down and if that force was just pushing down on the substrate it would damage it before getting sufficient pressure. CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 10 minutes ago, intelCore said: It needs force to push it down and if that force was just pushing down on the substrate it would damage it before getting sufficient pressure. Then explain why people can use Intel CPUs without a heatspreader. "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Just now, Godlygamer23 said: Then explain why people can use Intel CPUs without a heatspreader. I don't know exactly how that works but I assume the pressure you need is either applied by a custom made retention bracket or just the cooler itself with maybe some kind of support bracket on the substrate. And if it was just for cooling why is there a heatspreader then? You would get more surface with the cooler anyways and obviously better cooling without another layer. CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Just now, intelCore said: I don't know exactly how that works but I assume the pressure you need is either applied by a custom made retention bracket or just the cooler itself with maybe some kind of support bracket on the substrate. And if it was just for cooling why is there a heatspreader then? You would get more surface with the cooler anyways and obviously better cooling without another layer. Heatspreaders also protect the die from damage from the cooler, but people use the stock retention when using CPUs with no heatspreaders. Some manufacturers of water cooling parts have made special parts that elevate the cooler from the CPU to keep the mounting pressure from crushing the die, which is also much higher than the pressure to keep the CPU inside the socket properly. "It pays to keep an open mind, but not so open your brain falls out." - Carl Sagan. "I can explain it to you, but I can't understand it for you" - Edward I. Koch Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Heat spreaders were originally designed purely for preventing users from damaging the CPU die when installing aftermarket parts. You get better cooling performance if the heat sink directly touches the die, so there's no real point to having a heat spreader besides offering a mechanical safety. Though apparently delidding doesn't do a whole lot anyway so... I have a blog! And a list of guides I've posted Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 Author 49 minutes ago, Godlygamer23 said: It turns out GPUs are actually easier to cool. Er what? High end GPU's put out 2x as much heat as high end CPU's. 56 minutes ago, Hackentosher said: The die is much smaller than the heat spreader, look up what de-lidded CPUs look like. It also protects the CPU when you clamp a cooler onto it. And Mobile CPU dies are even smaller again and do not require heat spreader? 49 minutes ago, Godlygamer23 said: 56 minutes ago, intelCore said: Commons sense would tell me that since the CPU is laying on pins and is not soldered would need more spread force (applied by the cooler) to not lose contact. Also the CPU socket and the ledge needs something to press down on and if it was just the substrate I bet that would bend or brake. Many (particularly older) mobile CPU's also use a pin/socket system. It has only become common practice to solder them in in the last few years. The old socketed design mobile CPU's also had no heat spreader. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 6 minutes ago, Godlygamer23 said: Heatspreaders also protect the die from damage from the cooler, but people use the stock retention when using CPUs with no heatspreaders. Some manufacturers of water cooling parts have made special parts that elevate the cooler from the CPU to keep the mounting pressure from crushing the die, which is also much higher than the pressure to keep the CPU inside the socket properly. Okay so what point were you trying to make again exactly? I wanted to say that this is for the way of how the CPU is mounted into the socket. 5 minutes ago, Riley-NZL said: Many (particularly older) mobile CPU's also use a pin/socket system. It has only become common practice to solder them in in the last few years. The old socketed design mobile CPU's also had no heat spreader. Then I have to admit I do not know. CPU AMD Ryzen 5 5600X | Cooler Noctua NH-D15S | MB Asus ROG Strix B550 A-Gaming | RAM 2 x G.Skill Trident Z Royal silver 16 GB @ 3200 MHz CL14 | GPU Gigabyte GeForce RTX 3070 Vision OC 8G Case Fractal Design Define C TG | SSD(s) Boot: Samsung 970 EVO 250 GB, Programs: Samsung 970 EVO 1 TB, Data: Samsung 860 EVO 500 GB | PSU Seasonic Focus GX 750W Screen(s) Main: ViewSonic VX2758-2KP-mhd, Second: Asus PB277Q, Third: LG Flatron E2240T | Keyboard Ducky One (MX Blues) | Mouse Logitech G Pro Gaming Sound Card: Asus Xonar D2X PCIe, System: Edifier R1280DB | OS Windows 10, 64 Bit Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 6, 2016 18 minutes ago, Riley-NZL said: Er what? High end GPU's put out 2x as much heat as high end CPU's. It's questionable that they do. People are still confusing TDP as power consumption and I'm afraid it's even seeping into NVIDIA's product literature. Also is it the TDP of the GPU itself or all of the parts of the video card? The RAM and VRMs generate a non-trivial amount of heat too. So I'd wager the GTX 1060 is no hotter than say a Core i7-6700K once you remove those things. EDIT: As some measure of proof about this, let's take a look at Tom's Hardware's power consumption measurements on the i7-6800K. Their test setup is measuring the 12V CPU power cables using a current probe. Here's their power consumption measurements of the GTX 1060 using the same method (current probing the power lines, including the PCI Express slot). And according to http://www.anandtech.com/show/9266/amd-hbm-deep-dive/2 , GDDR5 at least on the R9 290X took up 15%-20% of its power. So if we take the GTX 1080's power consumption (110W for the entire card), subtract what VRAM is possibly taking up at the worst case, we end up with about 88W. Not sure what the VRMs, fan, and other house keeping circuitry do so let's just say 80W is what the GPU takes up. This is within 30W of a stock i7-6800K or 15W with an overclock to 4.0GHz (and matching it in the worst case). EDIT 2: Oh, before I get called out on misunderstanding, I'm saying GPUs aren't as hot as you think they are. I have a blog! And a list of guides I've posted Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
