DDR5-5600 Doesn’t work when set to correct frequency.
Solved by RONOTHAN##,
2 hours ago, Mike12345 said:and the motherboard can hold 8000mhz
Just want to say that this implies a god-tier CPU IMC. If you want it to actually work at XMP on more than 1-2% of CPUs, you would need to drop down to 7200 or 6800. Also, that 8000MT/s rating is only for 2x24GB kits, not 4x16GB or 4x32.
2 hours ago, Mike12345 said:ram is FF3D564G5600HC36BDC01
So you're trying to run 128GB of RAM. That's your problem. Running four dual rank sticks just doesn't work at high speeds. The absolute best CPUs can do 4x32GB at 5600MT/s, and a lot can't do above 4400MT/s without a ton of effort. If you care about RAM speed, ditch two of your sticks.
