Whats the better air cpu cooler
BlondeEskimo
so I have been struggling to decide on a cpu cooler for my i5 6600k which I will be doing some overclocking on,  first off I'd like to say that I want a very quite cpu cooler and I'm aiming for top price of about $80 cad (about $60 usd) and it needs to look good, I personally hate the look of the noctua fans, so here are the two picks I'm trying to decide between
Be Quiet! Dark Rock 3: I love how it looks but it only has one 135mm fan so is it worth the price? and I hear its a nightmare to install.
Phanteks PH-TC14PE_BK: looks pretty awesome and has 2 140mm fans.
I also love the look and price of the Cryorig h7 but its not available in Canada sadly otherwise id pick it up without a doubt.
do you guys have these cpu coolers? what temps are you getting on base clocks and or overclocks?
do you guys have any coolers you think I should take a look at?
btw I'm using the fractal design r5 so it was 180mm cpu cooler clearance.
a closed loop liquid cooler may be able to out perform both
Good luck, Have fun, Build PC, and have a last gen console for use once a year. I should answer most of the time between 9 to 3 PST
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Sapphire RX 6700XT  Nitro+, Corsair RM750X, 500 gb 850 evo, 2tb rocket and 5tb Toshiba x300, 2x 6TB WD Black W10 all in a 750D airflow.
GF PC: (nighthawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Strix GTX970, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb Adata XPG 6000 lite, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
PSU Tier List      Motherboard Tier List     SSD Tier List     How to get PC parts cheap    HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 60D, 24-105 F4, 50mm F1.4, Helios44-m, 2 Cos-11D lavs
At that point I'd just get liquid cooling.
✨PC Specs✨
AMD Ryzen 7 3800X | MSI MPG B550 Gaming Plus | 16GB Team T-Force 3400MHz | Zotac GTX 1080 AMP EXTREME
BeQuiet Dark Rock Pro 4 Samsung 850 EVO 250GB | NZXT 750W | Phanteks Eclipse P400A
Extras: ASUS Zephyrus G14 (2021) | OnePlus 7 Pro | Fully restored Robosapien V2, Omnibot 2000, Omnibot 5402
Good luck finding a 240mm AIO for $80 CAD. All you're gonna find in that price range are 120mm AIOs which have terrible performance for your money. Both coolers will outperform them.
@BlondeEskimo, the Phanteks PH-TC14PE slightly edges out the beQuiet! cooler so I'd get that instead.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
Just get the Dark Rock Pro 3. It has 2 fans and is easy to install. Make sure your RAM can fit under it though. To give you an idea of how low it hangs, my GSkill sniper sticks have <1mm of clearance.
If you like everything about the Noctua NH-D14 or 15 aside from the poop-colored fans, consider that you can buy a cheaper single-fan version, then use the all-gray Noctua Redux NF-P14R to take both slots. It does add about $30 US to the cost of an already-expensive cooler, though.
Between the two options you've got up there, I'd go with the Phanteks. beQuiet makes some wonderful fans and coolers, but the Phanteks cooler you have up there just flat outmuscles the Dark Rock 3.
Aerocool DS are the best fans you've never tried.
no but a 140 AIO should do well
I support this message
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
i had looked at the AIO water coolers but they are in most cases a fair bit louder unless you go for the higher end ones
Still pales in performance in comparison to either. 240mm should be the minimum if you're going for an AIO.
So I decided to just go the extra $60 and pick up the Corsair H110i GTX 104.7 CFM Liquid CPU Cooler and I'm replacing the fans with 2 corsair af140 quite edition.
My other option on fans was Fractal Design GP14-WT 68.4 CFM 140mm so I could have all fans match but I hear the af140s are better
Consider different fans if you're going to replace them. There are better fans out there at the same price, like Cougar or Fractal, for instance.
