How many warning points is it possible to get?
Solved by colonel_mortis,
It's neither an issue nor a bug - it's just a question about the forum.
There is no hard limit to either of them, and it depends on a lot more than just the points that you have. The points are effectively just a way of us expressing to you how bad what you did was.
Featured Topics
azyrroth ·
Posted in Home Theater Equipment0 -
Andrew john ·
Posted in New Builds and Planning10 -
2
1
rangh ·
Posted in Graphics Cards1 -
pilgr1mag3 ·
Posted in Troubleshooting7
