External HDD uncorrectable sectors, how to fix?
When I am watching a video or copying files, it stops working and gives me I/O error. Some files are fine, but other files are broken. I have done a format on the hdd, but I'm not sure how to fix this issue. Usually use the Windows tool to check errors and repair drive but that does not seem to work here.
My friend said, that I can proabably move the bad sectors to a different partition, and use the healthy partition, but is that the correct way to do it?
DiskInfo64_NPSWpy6hKu.jpg.441c6697b4a4d72cca6d5381174b9006.jpgUntitled.png.2b50b178575b7744ff22cf5aee8c71ae.png
image.png?ex=664202e1&is=6640b161&hm=e28b53980c21f792b8a3a9a13900aab6182828bf1f32296051e225b10a51fa7d&
Sorry, but the drive's dying. It should be able to correct for bad sectors by transparently remapping them to space reserved for that purpose, but either it's out of spare sectors or it's failing faster than it can correct itself. Even if you 'partition around' the bad sectors, you're only staving off the inevitable.
Lifeboat the important data to another drive as soon as possible, then replace that drive with a new one.
I see, I usually used this hdd as a NAS by mounting it to raspi. Is there a better way to do a NAS than what I am doing? If im going to buy a new HDD, what should I get?
You can also try a full format, or do a write scan using a program like victoria. If you can get those 304 (130 in hex) pending sectors to reallocate, you could keep using this drive for non important data, etc.
This is how you would do it on much older drives, that didn't support sector reallocation (before 1997 i believe?). With modern drives, this isn't an ideal way to do it, especially on a smr drive like this one.
The reallocated sector attribute will fail before this happens. Its currently at 78/100 with a threshold of 36.
It's dead, backup and replace, if you can, buy CRM one.
To mamy realocated sectors on this one, to trust it.
CPU : Intel 14gen i7-14700K
COOLER :  Thermalright Peerless Assassin 120 White + thermaltake toughfan 12 white + Thermal Grizzly - CPU Contact Frame Intel 13./14. +  Coollaboratory Liquid Ultra
GPU : MSI RTX 2070 Armor @GPU 2050MHz Mem 8200MHz -> USB C 10Gb/s cable 2m -> Unitek 4x USB HUB 10 Gb/s (Y-HB08003)
MOBO : MSI MEG Z690 UNIFY
RAM :  Corsair VENGEANCE DDR5 RAM 64 GB (2 x 32 GB) 6400 MHz CL32 (CMK64GX5M2B6400C32)
SSD : Intel Optane 905P 960GB U.2 (OS) + 2 x WD SN850X 4TB + 2 x PNY CS3140 2TB + ASM2824 PCIe switch -> 4 x Plextor M8PeG 1TB + flexiDOCK MB014SP-B -> Crucial MX500 2TB + GoodRam Iridium PRO 960GB + Samsung 850 Pro 512GB
HDD : WD White 18TB WD180EDFZ + SATA port multiplier adp6st0-j05 (JMB575) ->  WD Gold 8TB WD8002FRYZ + WD Gold 4TB WD4002FYYZ + WD Red PRO 4TB WD4001FFSX + WD Green 2TB WD20EARS
EXTERNAL
HDD/SSD :
XT-XINTE LM906 (JMS583) -> Plextor M8PeG 1TB + WD My Passport slim 1TB + LaCie Porsche Design Mobile Drive 1TB USB-C + Zalman ZM-VE350 -> Goodram IRDM PRO 240GB
PSU :  Super Flower leadex platinum 750 W biały -> Bitfenix alchemy extensions białe/białe + AsiaHorse 16AWG White
UPS :  CyberPower CP1500EPFCLCD -> Brennenstuhl primera-line 8 -> Brennenstuhl primera-line 10
LCD :  LG 32UD59-B + LG flatron IPS236 -> Silverstone SST-ARM11BC
CASE :  Fractal R5 Biały + Lian Li BZ-H06A srebrny + 6 x Thermaltake toughfan 14 white + Thermalright TL-B8W
SPEAKERS :  Aune S6 Pro -> Topping PA3-B -> Polk S20e black -> Monoprice stand 16250
HEADPHONES :  TOSLINK 2m -> Aune S6 Pro -> 2 x Monoprice Premier 1.8m 16AWG 3-pin XLR -> Monoprice Monolith THX AAA 887 -> 4-pin XLR na 2 x 3.5mm 16 cores OCC 2m Cable -> HiFiMAN Edition XS -> sheepskin pads + 4-pin XLR na 2 x 2.5mm ABLET silver 2m  Cable -> Monoprice Monolith M1060 + Brainwavz HM100 -> Brainwavz sheepskin oval pads + Wooden double Ɪ Stand + Audio-Technica ATH-MSR7BK -> sheepskin pads + Multibrackets MB1893 + Sennheiser Momentum 3 +  Philips Fidelio X2HR/00 + JBL J88 White
MIC :  Tonor TC30 -> Mozos SB38
KEYBOARD : Corsair STRAFE RGB Cherry MX Silent (EU) + Glorious PC Gaming Race Stealth Slim - Full Size Black + PQI MyLockey
MOUSE :  Logitech MX ERGO + 2 x Logitech MX Performance + Logitech G Pro wireless + Logitech G Pro Gaming -> Hotline Games 2.0 Plus + Corsair MM500 3xl + Corsair MM300 Extended + Razer goliathus control
CONTROLLERS :  Microsoft xbox series x controller pc (1VA-00002) -> brainwavz audio Controller Holder UGC2 + Microsoft xbox 360 wireless black + Ravcore Javelin
NET :  Intel x520-DA2 -> 2 x FTLX8571D3BCV-IT + 2 x ASUS ZenWiFi Pro XT12
NAS :  Qnap TS-932X-2G -> Noctua NF-P14s redux 1200 PWM -> Kingston 16GB 2400Mhz CL14 (HX424S14IB/16) -> 9 x Crucial MX500 2TB ->  2 x FTLX8571D3BCV-IT -> 2 x Digitus (DK-HD2533-05/3)
Quote
Your friend is wrong, the correct way to treat any failed sectors is to toss the drive and get another one.
