hello fellow doges
my cpu temps are at 69-74C at idle
my specs are
4790k
H100i Gtx
z97 mark S
16gb ripjaws z
sapphire r9 290x 8gb vapor-x
thinking of changing le thermal paste, what do you think?
what the hell lol, resit cooler and apply new thermal paste. you might have put too much on.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408150
I'm pretty sure the H100i comes with it pre-applied.
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408169
thnx bby ily <3
Reseat ur damn cooler
will do
Check if the fans are spinning.
using noctua ones so yesh the are
i would certainly do that, i wouldnt even try load tbh, see if it is tight in place, and make sure pump is working properly, from my experience you can feel the water moving through the tubes.
i havent done load because i dont wanna kill my cpu
"release your inner doge"
-doge 2069
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408198
Pre-applied thermal paste sucks. You might be able to spread it out better by twisting the waterblock back and forth a couple times to squish it out.
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408210
I think you have your backplate wrong, common mistake (made it myself too)
There are 2 spacings in it at one side, the 2 top screws of the socket should be there. Check that first.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408218
Yah, probably replace it with arctic silver 5. Small dot or X shape.
is arctic silver 5 good
-snip-
Arctic silver is one of the best.
To be honest, I wouldn't recommend Arctic Silver. It used to be the very best, but now there's very little difference between it and cheaper solutions. There's also TIM like MX-4 which performs just as well, but doesn't have the same risks of conductivity.
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408223
nah, i had normal temps like a week ago. and now everythings going derp
-doge 2069
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408225
Much heat, much trouble :D
Try to remount the cpu block, also feel if the tubes are mildly warm.
Maybe try to read the pump speed? There is a 3-pin plug with 1 tiny wire, that one gives you the pump speed.
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408245
Feel if the pump is spinning, you should be able to feel it I would imagine.
System specs
  • Graphics card: Asus GTX 980 Ti (Temp target: 60c, fan speed: slow as hell)
  • CPU: Intel 6700k @ 4.2Ghz
  • CPU Heatsink: ThermalRight Silver Arrow Extreme
  • Motherboard: Asus Maximus Viii Gene
  • Ram: 8GB of DDR4 @ 3000Mhz
  • Headphone source: O2 + Odac
  • Mic input: Creative X-Fi Titanium HD
  • Case: Fractal Design Arc midi R2
  • Boot Drive: Samsung 840 Pro 128GB
  • Storage: Seagate SSHD 2TB
  • PSU: Be quiet! Dark Power Pro 550w
Peripherals
  • Monitor: Asus ROG Swift PG278Q
  • Mouse: Razer DeathAdder Chroma (16.5 inch/360)
  • Mouse surface: Mionix Sargas 900
  • Tablet: Wacom Intuos Pen
  • Keyboard: Filco Majestouch Ninja, MX Brown, Ten Keyless
  • Headphones: AKG K7xx
  • IEMs: BrainWavs S1
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408250
yes and artic silver 5 = 200 hour cure time, so you wont get best performance level until 200 hours passed
Nono, it's 69 :D But aside from trolling, it might take a while. But you should be able to use it right away.
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408253
Obama.
Dinkelburg...
@ OP: Must be backplate.
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408353
hello fellow doges
my specs are
4790k
H100i Gtx
z97 mark S
16gb ripjaws z
How warm is it inside? wat are the Inside temperatures?
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
https://linustechtips.com/topic/401159-4790k-idle-temps-69c/#findComment-5408383
