Why are CPU's so small?
Why not make them bigger for full towers? Like I don't understand how the phsyicallity works but why is it such a small chip? A graphics card is much larger.. .why not cpu? Why not make RAM bigger? Wouldnt it help?
https://linustechtips.com/topic/383318-why-are-cpus-so-small/
A GPU core is actually smaller you know.....
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175252
The only reason a GPU is bigger is due to it's physical die size and that its essentially a motherboard with a massive cooler on it.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175263
I think is just because CPU usually can make more data than the rest of the system can handle, so... If they had more computational power, you just wouldnt notice... also, the paths between chips inside the CPU needs to be as small as posible to process the information as fast as they can, so... yeah, the small factor just increase the performance.
I'm from Spain so English is not my main language but I'm trying to make my best not writing any typo.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175267
The actual chip on the GPU is smaller than a CPU. When a transistor is 22 or 14 atoms across, it is going to be much smaller.
And what is the point of a bigger CPU?
Bro they are not measured in atoms, there is a difference between a nano meter and a atom.
You can fit 5 silicon atoms in a nano meter.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175297
I think it's all a matter of money. I don't know if this is true or not. So don't quote me on this. But we are essentially get souped up laptop/mobile chips. That's why it's small. I think it would be more expensive to manufacture chips independently of laptops from desktops. I might be totally wrong so yea... I know nothing.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175304
Because todays size of CPU are infinately more practical then having to build a computer the size of a shopping mall. i mean, if you want to build a computer with a 1950s shopping mall sized CPU then great go for it. But i hope you're not planning to go to lan parties with that setup
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175305
A Graphics chip is as small (if not smaller) than a CPU.
It's just the cooler and all the memory on it that makes it bigger.
You're comparing a GPU vs. CPU.
You should be comparing a GPU with a CPU, RAM and a CPU cooler.
Those sizes are more similar.
(By the way, you have some bigger CPU's. I believe Xeons are bigger)
NVIDIA-GeForce-GTX-980-Graphics-Card-Hea
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175310
Dies are manufactured from silicon wafers that DO have constrianed size. Making dies larger is more expensive because more material is required to make a certain number of chips.
Increasing die size further reduces yield because there is more opportunity for something in the die to go wrong, requiring that it be binned lower. This further drives up price.
Finally, die size HAS increased - but it is far more economical and beneifical to shrink the transitors.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175321
It's because the longer a electrical circuit is the longer it takes to send a signal across. Also the bigger a transistor is the more heat it produces while doing the exact same job.
You get more performance from having it be smaller.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175322
I said don't quote me god dammit xD
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175325
I don't think anyone who buys a Xeon E7 4850 is complaining of it's relatively small size.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175328
why should they be big? if we can make them smaller then why not. it doesn't alter performance, well i guess the smaller the chip the faster since the data has got less ground to cover than if the chip was bigger. so it does alter performance (sorry i lied...  :ph34r:) - for the better.
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175417
Mainly material costs from my understanding at least in terms of die size, cause to make this it costs millions if not billions of dollars of equipment and R&D:
That's why wafers are also round if you were wondering.
265051_Produkcja-procesorow-i-polprzewod
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175444
It used to be big if you'd look up its history but then shrinking while improving it has more advantages from performance to cooling to physical size and so on.
| CPU: Ryzen 5 3600 | MoBo: MSI B450 Tomahawk Max | RAM: T-Force Delta RGB (2x8) 16GB 3200MHz (Black) | GPU: Gigabyte GTX 1660 Ti OC | Case: NZXT H500 (Black) | HDD: WD Black 2TB + Seagate Barracuda 4TB | SSD: Crucial MX500 2TB | PSU: Seasonic GX-550 | Monitor: 3x Asus VC239H |
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175475
the smaller it is, the shorter distance the electrons have to travel - it becomes faster. thats why they have become smaller and smaller.
CPU: r7 5800x3D;  GPU: RTX 3090ti; RAM: 48GB DDR4; MoBo: ASUS CH VII HERO x470; PSU: Seasonic Prime 850 Titanium; Case: Be Quiet! Dark Base 900 PRO; SSD: Kingston 120 GB; HDD: 1x 500 GB 1x 2TB 1x 3TB;
My Anime List 300+ completed
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175505
1)Smaller chips need less material to produce = they're less expensive = good.
2)Smaller chips = smaller distance electricity has to travel = less heat = good.
Why would you want bigger chips?
CPU: Ryzen 3 3600 | GPU: Gigabite GTX 1660 super | Motherboard: MSI Mortar MAX | RAM: G Skill Trident Z 3200 (2x8GB) | Case: Cooler Master Q300L | Storage: Samsung 970 EVO 250G + Samsung 860 Evo 1TB | PSU: Corsair RM650x | Displays: LG 27'' G-Sync compatible 144hz 1080p | Cooling: NH U12S black | Keyboard: Logitech G512 carbon | Mouse: Logitech g900
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175568
They often are.
2011-v3 is quite a bit larger than Haswell.
Those goofy 38 core processors are also a little bit bigger than that socket.
Anyway the focus for consumer CPU's isn't adding more cores or even offering performance improvements.  It's offering nearly identical performance (although still better) while using much less power to do it.
It's also about offering a decent iGPU capable of doing things most non-gamers use computers for.
Anyway, the cores keep getting smaller and the iGPU keeps getting bigger because Intel is not going to change their i3/i5/i7 lineup until they have to.
4K // R5 3600 // RTX2080Ti
https://linustechtips.com/topic/383318-why-are-cpus-so-small/#findComment-5175570
