FX 4300 Not good enough for Batman Arkham Origins
Guest Console Peasant
Go to solution Solved by Faa,
Unfortunately for you I actually do know quite allot about computer hardware and am learning a bit more almost each and everyday. I also have the common sense to not spend money on the AMD FX line of CPUs which is allot more sense than many PC users have LOL. Have a good night man.
Well, just be constructive, don't just yell here "AMD sucks lololol, Intel better". Prove your points, make some valid arguments, be detailed, earn the credits you have to deserve and then you have the right to bash AMD. There's nothing wrong with bashing AMD, if that's all you do without being constructive then it's trolling - the right place to do that would be youtube. Most people just link a benchmark or two and compare the prices between AMD & Intel and it's always Intel offering a better value as most people here are gamers. Start off with accepting your mistakes, cant exactly remember what you've been saying way before you bought the i5 but it was completely wrong. Just do what I said and only die-hard AMD fanboys will hate you here for hurting them with the truth.
Bought Arkham Origins yesterday and my fx 4300 is bottlenecking it. So I got mad and I ended up ordering an asus z97k and a 4690k. I'm so done with amd chips bottlenecking my system (fx 4300 cannot even play minecraft in multiplayer @ 60FPS, but keep in mind that's because it's unoptimised and OGL)
This post is a warning to others who might get AMD because I don't think I can fix this, I put the game on the lowest settings and it still dropped constantly. If it's a game problem them I'd appreciate if you could tell me a fix, but other games do get bottlenecked by the fx 4300
remember that it's $100...
a pentium will do the same or worse at stock
Even a Q6600 outperforms a 4300.
I see you use an 8320, how does that perform in Arhkam Origins?
You should be able to play that game on an FX4...  Maybe your motherboard is causing throttling?  Either way, you will be worlds better off with an i5.
"I genuinely dislike the promulgation of false information, especially to people who are asking for help selecting new parts."
Had nothing to do with the FX.
My guess is you had physX on.
Enjoy your upgrade though.
4K // R5 3600 // RTX2080Ti
https://www.youtube.com/watch?v=WgD-ThvVxSs
no phsyx, cpu usage on 100% (hwinfo osd)
2nd one is arkham city by the way
edit: the benchmark runs at 60 most of the time, but in game it lags way more, useless benchmark..
I played the game on my Phenom X3 8750B and GTX 650 at 900p. Got 30-40 fps constant, settings high, AA off, Physx off. It is totally not a CPU heavy game, there is some other issue in your system.
30-40fps constant.. thats not what I want. the Batman games aren't that demanding and should run at 60 constantly... But there is no harm to check my PC, what do you reccomend is wrong?
Smells like an Intel fanboy propoganda.
Spose I might be, but this chip sucks, no fanboyism involved. I might post about how the intel one goes aswell, it might be bad aswell, but it better not be ffs.
another satisfied AMD Customer
lmao !
In your sig.
" Motherboard: Asrock 960GM (U3S3/FX)  RAM: 8GB Team Elite 1600Mhz + 4GB Samsung 1333Mhz"
So what you are saying is that you put an FX cpu on a garbage board with the wrong chipset(760G), 2 different ram makes and models with low speed, and you say your having problems.
You dont say....
Listen to Priller above. Are you really mixing RAM? If so, there you go that's the issue. Otherwise maybe you have CPU based Physx enabled. Physx takes quite a big toll on CPU performance, so disabling that will the gameplay a lot more smoother with less dips and higher fps. Also I don't see the PSU in your signature, check if your PSU is actually able to power the system properly. Underpowering the components under load is very dangerous to their health. Apart from those, check if you are not running any heavy CPU based tasks in the background while the game is running. And also monitor stats like GPU, CPU, RAM, VRAM and fps with MSI afterburner so you can better determine which part is causing the issue. On a 270x, I can assure you can max out the game all the way and still get around 50 fps at 1080p. Batman games are not GPU or CPU heavy at all, I've actually even run the game using a GTS 450 at med-high at 1080p above 30 fps.
Tbh that's about what I got when the game first came out before crossfire was supported.
Poor AMD I was Your Fanboy
@terrytek
In your sig.
You dont say....
I wouldnt usually blame a 760g board as ive run phenoms on an m5a78l-m/usb3 overclocked fine drawing way more power than an fx4300, though its asrock so...maybe this time,  that 3+1 vrm also...
I've run moh warfighter maxed out at 105fps with my r9-290 with an fx4100 so obviously its rubbish i should be getting 8000fps.
i dont recommend and fx4300 EVER not because of performance issues because there's far worse but for the value an fx6300 is usually a few bucks more and will still work on a cheapo £50 board.
id put money on op having some other issue and i bet hes never checked to see if its actually the game using 100% of the cpu in task manager, considering the mis-matched build im guessing op is part of a bot net, a million virus's and has "a few" chrome extensions.
"I put the game on the lowest settings and it still dropped constantly" yeah im sure the cpu really cares about graphics settings.
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
Nope it's the FX 4300 cause it's junk. My Phenom II x4 955 OCed could not play Batman AO as well so I also upgrade to Z97X and 4690K LOL. Now there are no issues with poor performance.
that game run's on a potato really it require almost zero processing power, the FX CPU is not the cause for bad performance here.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 2 VR
