So, I was doing what we in this forum do best, overclocking my 780 Ti. After getting my clocks to my desired speed, I ran Unigine Valley (which actually yielded me my highest score) and noticed about midway through, an odd odor. It wasn't like "something is on fire" smell, it was like "is something really warm?" Kind of smell. Anyhow, I quit Valley and the smell was gone. Then I tried to reenact the situation, wondering if it was just an oddity, well I smelled it again, but much less potent. The smell SEEMS to be going away, but I'm worried about my expensive toys. My temps never exceeded 78 degrees Celsius. My original thought was that my VRAM was cooking, considering I cranked those higher than I ever have, then I thought maybe my power supply was causing it...
What're your thoughts?
Project Insomnia
CPU: Intel i5 4670K @ 4.6 GHz.   CPU Cooler: NZXT Kraken x40   Motherboard: ASRock Z97 Extreme6   Memory: Corsair Vengeance 8Gb.   Graphics Card: EVGA SC Geforce GTX 780 Ti   Power Supply: EVGA G2 850W   Case: NZXT H440
https://linustechtips.com/topic/177982-hot-plastic-smell/
RMA it
Specs
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389252
give the PSU backside a sniff when you run Unigine
or take out the GPU and see if there are any melted parts
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389266
THE END IS NIGH
Switch off the PC, take out the GPU and smell the motherfucker, if no returns come from that bloodhoud activity then begin sniffing other stuff (PSU) before the scent is lost.
Burning smells from the PC are a red flag.
BUT IT'S SO YOUNG!
I'll see what I can do about the sniffing. I wanna say it's not my 780 Ti BECAUSE I didn't touch the voltages.
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389305
RMA it
...and if it's not the GPU?
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389306
i say it possible the glue on the coils in the PSU are the cause of the burning smell
smell the backside of the PSU where the heat is exhausting
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389316
@JDS as one of my posts and now 2 of this man's posts have said take a sniff of the PSU.
Y U NO do this lol
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389331
The only problem is that my Ti blows air back there too...
Like I said, the smell seems to be going away, so your theory would be correct in the sense that once it burns the excess off, it'll stop smelling.
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389343
the only concern is that with your GPU OC
you are putting stress on the PSU
which is why it gives off that smell
if it does go away, not so much of a concern
but if the smell does stay, I will worry and get that PSU replaced
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389351
Y U NO do this lol
I inhaled as much as my lungs would allow. You should be proud considering burning plastic is a carcinogen...
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389368
If I'm not upping voltages how is there more stress on my PSU?
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389375
Well have you found the source of the smell?
I can't really say. It's definitely coming from the back, but that still leaves both the Ti and the PSU...fack.
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389388
more OC = more heat
more heat = more cooling
more cooling = more power
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389391
more OC = more heat
Touché. Unfortunately I have to be at work in 5 hours, so I must go to bed for now. I contacted EVGA and they said it could be some adhesive residue burning off, and if it still smells after a day or two to contact them. What other ways can I find out of it's my PSU? The smelling is inconclusive.
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389412
http://forum.corsair.com/v3/showthread.php?t=113734
http://www.reddit.com/r/buildapc/comments/1pbbua/desktop_pc_starts_to_smell_of_burnt_plastic_and/
hmm i just did a quick google
CX600 are known to burn itself out and that smell the other user have and failing to boot up
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389428
try looking around for any other damaged parts
Specs
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389542
Open your case up and unscrew your PSU, put it somewhere away from your gpu and stress your system. That'll help you be able to tell where it's coming from.
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389563
You could take your psu out of your build (but leave it connected) and while running unigine hold the exhaust up to your face. That way you could seperate the air coming from your gpu und your psu to find out whats actually smelting.
 Intel Core i7 4790K || G.Skill 16GB DDR3 || MSI GTX 970 Gaming 4G || Fractal Design Define R5 || Asus Gryphon Z97 || EVGA SuperNOVA 750G2 || Crucial MX100 256GB || Noctua NH-D15
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2389565
That's the plan for tonight. When I'm home from work I'll be sure to give that a go.
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2390967
Do we think 600 watts is enough for OCing a 780 Ti and a 4670k? If I'm drawing too much power from my PSU then I'm sure that's the problem, as already mentioned.
Project Insomnia
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2391708
I'm running an i7 2600k overclocked and a GTX 780 overclocked on 500W... Made by OCZ... So you tell me if 600W is enough :P
https://linustechtips.com/topic/177982-hot-plastic-smell/#findComment-2391897
