Questioning r9 290 for my build...
If you're only doing 1080p right now then just get a tri-x 290; they'll be easy to find for a while yet, are cheaper than a 290x, reliable and take up fewer slots. If you do want to go 1440p, there's no need to have a matching card, but I'd imagine this model will be the easiest to find a second of. That or the Twin Frozr one.
LMAO
Yes it makes the biggest difference in the world.
Throttling?
A PCS+ R9 290 beats a reference R9 290X AND Reference GTX 780.
Watchdogs uses 2,7GB at 1080p and this will be normal in the next 1-2 years.
The Ps4/XboxOne can use 3-4GB Vram and the devs will use it.
Nvidia always bottlenecks their cards with not enough Vram.
They did it with the 1,5GB on the 580, they did it with the 2GB on the 680, and they did it with the 3GB of the 780.
Coming from someone that has SLI and 3gb cards, and seeing my vram usage at 1440p & also using 5760x1080 previously, on crysis 3, bf4, and other AAA titles, I can say that 3gb is not the limiting factor.
If those games barely hit 2.4gb-2.5gb at 1440p with AA + every setting at max, there's truly something wrong with the way watchdogs uses resources if it needs that much for 1080p, because it doesn't look good enough to warrant that kind of VRAM usage IMO.
It's most likely a VRAM Cache that is making it appear to use that much, rather than actually using that much. Or it's the worst coded game in history.
I'd definitely recommend this card for air cooling configuration, in many of the reviews I've seen, the core overclocked to almost the same level as the 290X Lightning does, albeit with a lower memory clock due to MSI using cherry-picked Samsung memory chips.
when talking about the 780v290/X no question the 290 beats it
, but i believe 3GB is enough For 1440p or even 1600p because the 780Ti has the Power to take on high res even with 384bit bus $
Oh, it OCes like a dream
After the 7% off code it's $351.20... this is FAR too good to pass up. Thanks for the help everyone, I think Newegg just made my decision easier.
