Do I need to quote them?
Solved by Oshino Shinobu,
You should quote them.
By default, if you post a topic you'll get notified when someone replies, but others won't unless they manually follow the thread, so you should quote them so they get notified you responded.
EDIT: It also helps make it clear who/what you're responding to if there are multiple posts, so best to quote reply either way.
- Prev
- 1
- 2
- Next
- Page 1 of 2
- Prev
- 1
- 2
- Next
- Page 1 of 2
Share
Followers
5
