iGPU help needed
Go to solution Solved by RONOTHAN##,
1 minute ago, BotherRed said:
X670E
There's dozens of these, which one specifically?
So would just need to refresh the CMOS possibly?
Probably.
So my GPU  was acting up and I needed it to be fixed. Took it out and have already shipped it.
Was slightly hoping I could just plug and play it as I built a PC for my mom which only uses the iGPU in the CPU. But through a little bit of searching, figuring out that because I had a GPU in my system, it maybe trying to use it's driver's instead of the iGPU.
Its a 7950X3D So it does have one. Motherboard code is A0 so it posts fine. Just no display out through DP or HDMI
CPU: AMD Ryzen 9 7950X3D / GPU: MSI Ventus RTX 3090 VENTUS 3X 24G OC / RAM: Corsair Vengeance 96GB (2x48GB) DDR5 DRAM 5600MHz C40
MOBO: Gigabyte X670E Aorus Xtreme/ NVME: Crucial T700 Gen5 NVME M.2 SSD 2TB Case: Fractal Torrent
 PSU: Seasonic TX-1600 1600 Watt / OS: Win 11 Pro / UPS: CyberPower CP1500PFCLCD PFC 1500VA/1000W
https://linustechtips.com/topic/1569144-igpu-help-needed/
What motherboard are you using?
The iGPU should just work in this setup, it's weird that it's not. What is probably worth doing is a Clear CMOS just to make sure your motherboard didn't automatically disable the iGPU when the dGPU was installed but didn't re-enable it when the card was removed.
https://linustechtips.com/topic/1569144-igpu-help-needed/#findComment-16399365
X670E
https://linustechtips.com/topic/1569144-igpu-help-needed/#findComment-16399372
Probably.
Apologies, the moment I sent it I knew I should have specified. Sorry.
X670E Aorus Xtream v.1
https://linustechtips.com/topic/1569144-igpu-help-needed/#findComment-16399374
Probably.
That was it. Just needed to reset
https://linustechtips.com/topic/1569144-igpu-help-needed/#findComment-16399435
