cleaning [SOLVED] PC cleaning and dusting, canned air alternatives? Can you use an air compressor to clean your PC?
Sorry for the late reply. I have been away and didn't have much time. Here is my final verdict, which I shall also mark as the solution to my own question:
Anyways, I decided to buy a normal 25L oil lubricated piston air compressor for around $120. I could not be happier with it! I did a lot of research about oilless air compressors and in-spite of the fact the technology has moved quite a long way ahead, people still seem to be complaining about the lack of long-term reliability of oilless air compressors.
CONS about air compressors:
- Water condensation is a potential issue in BOTH designs - whether the compressor is oil lubricated or oilless doesn't make a difference in the amount of water condensation, as that is the direct result of the environment you're working in as well as the inherent nature of the physical process' taking place during air compression (and rapid expansion).
- The only problem with classic oil lubricated air compressors is that some oil vapour may also enter the main tank and thus get discharged through your e.g. blow gun.
- You need to maintain your air compressor by: performing service such as cheap oil changes and regularly draining your tank (after every use or at least one a week) to prevent corrosion due to moisture build-up.
- There are different types of air compressors to choose from. You can buy a normal oil lubricated piston air compressor, which is very loud, or a slightly quieter belt-driven air compressor. There are also EXTREMELY quiet rotary screw air compressors and others - do your own research!
SOLUTIONS:
- To combat moisture and oil discharge you can use a cheap ($10) oil-water separator (there are also more professional options available), which is essentially just a little filter that traps most water, oil and other (solid) particles from exiting out of your blow gun, meaning it's going to most likely be completely safe to use with blowing out your PC - this is the case in my situation as I have NEVER noticed any water, oil or dust exiting my blowgun (and yes, I have tested this).
Here you can see a cheap oil-water separator and the amount of moisture build-up after about 1 hr of usage
PROS:
- Cheap.
- Cheerful.
- Output air pressure CAN easily be regulated, so no need to worry about damaging your components.
- EXTREMELY versatile.
- Can be used to blow up car tyres, with air tools, etc. You can really do a LOT of handy-work with air compressors.
- Great investment.
- Will most likely last you a long time (10 + years).
- etc.
TLDR: DataVac's are WAAAY too expensive for their lack of versatility. You can do a lot more with air compressors. Get an air compressor.
