Audio Transfer
Solved by Kilrah,
1 minute ago, NinJake said:Was it fairly easy to set up @Kilrah?
Yep, was straightforward. You really want both machines wired, with fixed IPs, set the transmitting machine to send to the IP of the receiving one, then once started on the receiving end right click on one of the "Stream name" fields and it should find the stream, click on it, select the destination strip and you should be good to go. Make sure to actually enable VBAN on the page
