Connecting Corsair RGB fans into a motherboard header?
Solved by thrasher_565,
7 hours ago, Origami Cactus said:So I have 2x Corsair ML140 fans just sitting around and gathering dust, because I don't have any commander units.
But I thought of making an adapter, and apparently you could adapt the corsair molex connector to 5v 3pin RGB.
Because I have 2 fans, I am thinking of making 1 adaptor with a splitter. It should work fine right? Someone on corsair forum said they got it working alright, but when set to white at 100% it could cause problems?
Tutorials I looked at:
i have a guide on it. can also just buy cables too. or cut them off and put a stander argb connector on it too.
