Is using (a lot of) bug spray near a running PC dangerous?
Solved by RONOTHAN##,
As long as you clean your computer somewhat frequently I don't see any reason why it would be dangerous. If you're talking about the aerosol kind, computers don't get hot enough to ignite it. If you're stalking about the spritzer kind, that has basically no reason to damage it. The most I can see it doing is damaging your fan bearings, or if enough of it builds up, causing temp issues and or shorts. All of those can be mitigated by cleaning your computer every once in a while.
